New Engine Baseline Complete
Old Oct 1, 2016 | 09:26 PM
03EBZ06's Avatar
Default New Engine Baseline Complete
I said I would post my combo when done, so here it is. Note, I am no dyno racer and I usually measure performance by a car's wt w/driver and the MPH it runs, but I was happy w/the numbers. A few friends and I are racing on Oct 8th, so hopefully I can give a go and see what its all worth.
The Combo:
416 CID LS9
ARP crank/rods/head bolts
CP gas ported 13:1 pistons made from a mold of my heads
Scat Pro Crank/Rods
MAST 265CC small bore LS7 heads (has 4" bore w/LS7 intake ports), 70cc chamber
Comp Cams Solid Roller 254/270-112+0 RT/NC lobes (0.716"/0.731"), lashed cold around 0.004" and 0.008" (lash cuz I know speedtiger is going to ask! jk!).
T&D shaft mount 1.7 roller rockers
Iskendarian solid bushed lifters
Manton 3/8" pushrods, 8.625"
Kook's Long Tubes 1-7/8"
LS7 water pump
Holley Hi-Ram LS7 intake and Holley Fuel rails
LS2 stock 90mm TB
LS7 52lb/hr injectors
VP 110 octane
The motor made 597rwhp/522rwtq. We are looking at this as a baseline to work from.
Here is a picture of the car:
2002 Z06 416 LS9<br/>
Old Oct 1, 2016 | 10:35 PM
KW Baraka's Avatar
Very nice numbers .....where were your peak HP & TQ?
Also......love the way that intake peaks through the hood.
KW
Old Oct 1, 2016 | 10:42 PM
DietCoke's Avatar
You'll pick up 15hp over 6k with a 102 tb and having the snout/turn opened up. I did.
Old Oct 2, 2016 | 01:19 AM
BOLO's Avatar
Nice results, congrats! Hopefully I will expect the same results from my build.
It's too bad you had to cut the hood for that intake.
Old Oct 2, 2016 | 05:46 PM
03EBZ06's Avatar
KW
thanks. I'll post the graph soon. YEAH. I kind of like the intake peaking through myself...
was told by a guy w/same motor as mine exactly that. he tested his and gained around 10. thats on my to do list.
Thanks. I'm good w/the hood and in fact kind of like the fact it doesn't look like the other billion Vettes out there. I can not stand the Vette hood scoops so that was out. Throws the body lines off.
Weaknesses in my setup are the TB 90MM and I may have went a little smaller than needed on the cam. 650 is not out of the question for your setup. In fact, I'll wait until you test it before I make any changes.
Old Oct 3, 2016 | 09:57 AM
hellbents10's Avatar
LS1Tech Sponsor
Awesome, I am digging the hood mod.
Old Oct 3, 2016 | 10:35 AM
speedtigger's Avatar
Old School Heavy
Originally Posted by 03EBZ06
I lashed cold around 0.004" and 0.008" (lash cuz I know speedtiger is going to ask! jk!).
I would have.
Where did it peak for TQ and HP?
Old Oct 4, 2016 | 12:32 AM
03EBZ06's Avatar
Originally Posted by speedtigger
I would have.
I believe it was 4700rpm for tq and 6200rpm for hp. I suspect the 6200 may have been a traction limit.
Old Oct 4, 2016 | 08:48 AM
BOLO's Avatar
?..thats kind of odd for it to peak that early with that size of a cam and that intake.
Old Oct 4, 2016 | 08:51 AM
Old School Heavy
Yep. I would have expected HP peak to be 7500 or so.
Old Oct 4, 2016 | 09:25 AM
03EBZ06's Avatar
we had some problems w/the tires I was using... no big deal
Old Oct 4, 2016 | 09:51 AM
AnotherWs6's Avatar
Somethings wrong with your hood.
Old Oct 4, 2016 | 09:57 AM
ss454327's Avatar
LS7 heads? Why didn't you go with the Mamo MSD on that thing? Would have stayed under the stock hood too...
Old Oct 5, 2016 | 12:34 AM
03EBZ06's Avatar
Next stop ¼ mile to do some testing...
2002 Z06
Old Oct 5, 2016 | 01:10 AM
tug686spd's Avatar
Now your talking! Time for the real test.
Old Oct 5, 2016 | 07:23 AM
psychosid30's Avatar
Love the intake peeking out of the hood. Makes it look aggressive as heck! Now you just need to powder-coat it...
Old Oct 5, 2016 | 09:07 AM
BOLO's Avatar
2002 Z06
This vette is gonna FLY! GL with the testing.
And as suggested, the intake would look nice powdercoated black.
Old Oct 5, 2016 | 09:22 AM
slow trap's Avatar
great results. being solid roller and with those nice heads, that cam is kinda small @ 254*,more like a 246* if it was a hr so something like a 262* would prolly pull to 7k or so. it prolly still carries to 7k cleanly so it will run a good number.
good luck : )
Old Oct 6, 2016 | 09:05 AM
KW Baraka's Avatar
Next stop ¼ mile to do some testing......
Results?
KW
Old Oct 6, 2016 | 11:25 AM
Smo's04Gto's Avatar
Great results. This is thru a M6? Can you post a dyno sheet ?
