DOD Delete and Cam Bearing Questions
Hey guys I have two quick questions. The first question is in regards to the DOD delete. I have a 5.3 out of a 2007 Yukon and I just got it back from the machine shop. I am going to do the DOD delete, and from searching on the interwebs I have seen people thread the holes circled in red (see pic below) and put bolts in the holes to block the oil passage. What are peoples thoughts on doing that, and is it necessary? I am using a LS3 valley cover, and while the block is bare I would like tap the holes now so I can get any metal shaving out before assembly.
My second questions is regarding the cam bearings. I had the machine shop hot tank the block, hone the cylinders, and put in new cam bearings. Once I got the block home I notice that the edges of the bearings look rough and somewhat cut. Is that what new cam bearings are supposed to look like?
I appreciate your guys help, and input.
Save
Thats what I was thinking as well. I may get some Allen bolts and put them in for piece of mind.
