What rods and pistons for lq4??
While forged pistons are much stronger they run looser clearances which allows oil past the rings and that oil can promote detonation.
You will need a "balance", just filling the crank ?
Not sure, if a "bad" case it could be the same price as when a forged CS was added with "native" 1850 BW.
My use of an OEM cast crankshaft is NOT common, so I ASK that Bob Weight value ?
Lance
Lance
Posting some link to the various products that you offer would be very helpful.
Andrew
Here are some rods I picked up from Lance they are 6" H-beam and they balanced out well out of the box the lightest 641.05 and heaviest was 643.53
After big end small ending them I was at 640.84 across the board I have been dealing with lance on a sbc 383 build using his ecu originally was going to just be efi with coil per cylinder but I had my engine seize due to a faulty gauge reading and overheating so I decided to build a block I had in the garage.
I will be honest with you dealing with him has been good if I can find it cheaper he supports that doesn't pressure me on it. But I have spent and saved allot of money dealing with him.
Scat, K1 or Manley H Beams with ARP 2000 bolts and a wrist pin upgrade would be my choice along with either a Manley or Wiseco piston with Total Seal CS AP Ring package. Peace of mind is worth a couple extra bucks IMO.
Andrew
The weight of the car is unknown, last time I weighed it it was right around 3500 with me in it I believe. But since then it has gotten a fab 9" full rear suspension with Viking coilovers, a th400, and race brakes all around, along with front Viking coilovers, and a few other weight reduction mods. For the turbo build it's going to receive a k-member, and eventually a 8 point cage including a window net kit. So the weight is really hard to guess unless I take the car out and weigh it right now, which isn't going to happen, is be willing to bet that et street pro's and ice/snow do not mix well together!!
Andrew
That's why I said the horsepower didn't matter, I wasn't trying to come off as ignorant, I understand it takes an xxx amount of horsepower to run what I want. I'm just not sure what that number is! And if it can be done with my combo/budget or not.
I have some K1 rods and wiseco pistons going in my spare 6.0 block though.
No answer was provided.
No one here, above, reminder you to measure the weight of the rod AND piston.
You can be lighter, NOT Heavier.
The "rods", there are two plants in China, Shenzgen Province.
They are next to each other as witness by myself.
The make most of the rods for the companies listed above, the Non-USA rods, the Non-Billet rods.
The REAL cost is the balance, with Mallory often required, in OEM crankshafts.
Then add the cost of a grind requirement ?
WHEN you add up the costs, a Forged 4.00"/4.10" crankshaft @ 1850 BW could cost LESS.
Lance
Also using stock polished crank
