LS3 Heads On LQ4 6.0 Help Needed
Drive ability requirements and you will get the cam to make you
Happy, Very easy to get the wrong cam with LS3 heads on a 6.0.
Good Luck.
Square/Rectangle LS heads are a little bit pickier when it comes to cam choice, but get it right and it'll pull from 2800-7100. At least mine does.
I have a 230/238 .626 lift in my 06 GTO with full ported heads. Had to cut valve reliefs in the pistons on mine. Both are running Cam Motion cams.
I put some ported L92's (milled .025) and a LS3 intake (w/NW92mmTB) on a stock LQ4 and it under performed IMHO. Cam 231/247 .617/.624 @ 113.
It made 426/383 through a stalled 4L60/10 bolt @ 3.42 gears. Pretty sure the lack of compression on those dish pistons is part of the problem
I'm convinced some good cathedrals and more compression would have done better.
The existing cam/head should really like the nitrous though!!
This motor/cam combo definitely needs more compression!!
