How to get an LS3 to 13:1 compression cheaply
Is there an inexpensive way to get there? Custom pistons my only option?
I'm interested in cheap, because if it gets too expensive, I figure I'll just bite the bullet and go with an ERL dry sleeve 440ci.
To supply the 13:1 - X:X is no problem for my service.
A note, you should be careful of pump E-85.
The camshaft should be specified with WIDE L/C's, good for the Hendrick head you have stated.
Will you keep the L-92 VVT ?
Lance
You could weld the chambers and angle mill the heads. With the stock bottom end it will be tough to get a real cam in it though with out cutting valve pockets in the pistons.
Not sure how fast your wanting to go but that type of compression for what it seems like your doing (street toy) I don't think you would need that much compression. To each their own just thought I'd share my experience with a pretty similar setup.
I flat milled the Trick flow 255cc GenX heads .150 new off the box had Patrick G spec a cam.
Still on ls3 intake manifold and throttle body my ls3 runs consistent 10.5 the first time to the track with only a 3,400 stall.
Combustion chambers are @ 45 cc compression 14.1 to one using Power Master 9509 starter with a 17lbs Braille battery.
OP here's a Christmas present for you enjoy it.
http://www.corvetteforum.com/forums/...track-day.html
Merry Christmas every one!
The L-92, LS-3, LS-7, 2006+ year LS engine uses my 60-2 (58x) TW.
THAT VERY ART allows for a static C.R. increase of .5 due to a more accurate Spark Instant.
Thus, that too would be a safety factor, yours as fitted by the OEM.
Lance
https://m.facebook.com/story.php?story_fbid=10155629637439126&id=66406912 5
https://m.facebook.com/story.php?sto...6&id=664069125
You where the motivator for me going to the machine shop to have .050 removed from my heads then went back and asked for another .050 about 3 days later return with the heads for another .050 they thought I was kidding I said no go for it by then we were like 5 thous from the accessory bolts holes threads but made it all work glad you inspired me thanks.
How much slippage would you see with a stall that tall do you know anybody using it on the street? I would love to have a hard hit 4000 and thinking too much in terms of slippage and traction requirements.
