Comp Conical springs; any usage reports yet?
The loads are near perfect for my application, and the reduced weight/mass at the top along with the lighter retainer makes these a very attractive spring to consider. I don't want to be the test pilot though....
I've been using the Comp 26926's with Ti retainer on this engine for the past year or so, but the valve train is not happy. All exh seals were removed by the inner spring, and then beat to crap.
I have a very strong preference to stay with the HR lifter. Using Morel 5294's. Good for 220 seat and 550 open loads.
LS7, .670 lift, Crower rockers, 85 gram exh valve, 7200 rpm fuel cut off.
I called Comp to ask about the 7230 Conicals, and must have gotten someone not familiar with their product (imagine that). He told me to use the springs I'm already using, and the Conicals would not support the lift. Waste of time.
I didn't have very good luck with them. I had one break on me while cruising the highway at around 1800RPM. I installed them with stock hardware and had well over the .060" coilbind clearance that I usually install springs to. I filled up the tank twice since installing them so maybe 500 miles on them when it failed. Never pulled it above 3500RPM, never went WOT, just cruising around.
I am running PAC 1218s and have good luck with them. I have about 2500 miles on them and spin them up to 6200rpm. In the back of my head I worry about dropping a valve but have been told that the PAC 1218s are a good spring and should last with a smaller cam. I am using PAC Titanium Retainers and their machined valve locks with LS6 Valves in my 243's to keep rotating mass down.
valve control.
If you find out anything you should let us know.
This could have allowed the spring to move around a bit and/or cause coil surge even at lower RPMs.
Then again they could just be giant piles of Llama feces for a .600" lift roller
If it's something with the spring, at least Comp can use the information to make a better spring. If it's something I did, well then I learn something new that I can do to avoid another issue in the future. We'll see though. I'll report back when I have new info to share.
