Ticking/ tapping noise, help!
Old 05-26-2017, 05:00 PM
BigEd_72455's Avatar
Originally Posted by cookseyb
Sounds like a broken or cracked exhaust manifold to me.. FWIW
cant be on mine, I have Hedman 45250 long tubes.. i cant speak for his.
Old 05-26-2017, 06:00 PM
jethro's Avatar
That's where I started, cause I thought exhaust leak as well. I have Sanderson shorty headers and have checked them a half dozen times. Thanks for the input, I'll probably check em again. Looking like I'm going to start tearing into rod bearings!
Old 05-26-2017, 06:27 PM
LS1Tech Premium Sponsor
tech@WS6store's Avatar
What valley cover do you have?
Old 05-26-2017, 06:30 PM
jethro's Avatar
Stock LR4 4.8. are there more than 1?
Old 05-26-2017, 06:39 PM
stevieturbo's Avatar
Originally Posted by jethro
Well ok I have an update but still have a tick. Isolated it to #4. Had the covers off and backed off the rocker, tick stopped.. no brainer, lifters bad right? Pulled head , replaced lifter, put it all back together, still ticking. Bad lifter out of the box? Crap. Pulled head again, replaced said lifter, still ticking. Not the lifter, tried switching rocker arms around, tick stays on # 4. Any thoughts at this point?
The biggest problem here is you do not know any history of the engine ?
It's pretty certain it cannot be fuel/spark related.
You've pretty much ruled out rockers/lifters ? ( try swapping rockers to another cylinder just in case ? )
You've identified a particular cylinder.
So everything is shouting some sort of piston or rod issue. When you had the head off, did anything look different about that cylinder ? Any photos ? Both valves definitely sealing fine and look normal etc ?
If you can live with the ticking...just let it tick til it breaks. If not, probably time to pull that rod/piston out.
Old 05-26-2017, 06:59 PM
Lr4 is gen3 not 4. Gen 4 4.8 in 07 is ly2 and has the afm bosses in the valley. While it doesnt have afm and a reg ls2/l92 valley cover with o rings in the bottom that seal off the bosses, they can leak causing low oil pressure on that cyl and make it make noise and possibly misfire also. this is true of only cyls 4 and 6 and 1 and 7 so you can see how it correlates to what you heard
Its just a thought thats why i asked. the lr4 is 24x and ly2 is 58 also. 2007 was a year for both controllers and both nba and nnbs trucks and gen3 and gen4 engines.
Old 05-26-2017, 07:15 PM
jethro's Avatar
Tech@ws6store, I realized that the motor is a gen 3 after I started the thread. I do see where you were headed with that. Like you said in 07 both versions were used. So no afm on this engine, I like your thought process though, thanks.
Stevieturbo, you are correct, no history, and that is less than ideal. No obvious damage or any abnormal wear when I had the heads off. I did move the rocker off #4 when I first got into it. It did stay at 4. I do think that lifter was bad. After lifter replacement, like I said I don't hear it in the valve train anymore. I did take valve springs off and all the valves seem to be functioning properly. I have the covers off at the moment and will move rockers again and check it again. Might indeed run it till it breaks and just put another motor in. By the time I pull it fix bearings, pay for machining and such, might be cheaper to just grab another engine. Thanks for the input though, I do really appreciate it.
Old 05-26-2017, 07:32 PM
Ive heard spun cam bearings do this. Ive seen a few on 4.8/5.3 blocks.
It def seems half engine speed so that should say valvetrain. Ive also hears ver loud sounds like this come from stray spark either from the metal boot cover or from boot to head/manifold as well.
Old 05-28-2017, 09:27 AM
Jimbo1367's Avatar
Thats what it first sounded like to me too. But, when he rev'd it, it didn't get louder. All the header/exh. gaskets I heard got louder when rev'd.
Old 05-28-2017, 12:40 PM
I went ahead and played it safe and pulled the engine apart to the block in my S-10. Found a ruined bearing as I stated earlier. To be on the safe side, I am taking the crankshaft tomorrow to a machine shop to have the crank turned down to .010/.010 and get new bearings. I would rather spend that small amount of money compared to having to find a whole new motor cause it chucked a rod or broke a piston or whatever else could possibly have gone wrong.
The following users liked this post:
Jimbo1367 (08-21-2023)
Old 05-28-2017, 06:06 PM
Raymond G's Avatar
Cold start piston slap maybe?? Seems like valvetrain noise but I have heard piston slap sound almost the same in these engines. Either way im with Big Ed on this one.
Old 08-15-2023, 05:47 PM
  #32
JD Haney's Avatar
Default Ticking noise, timing tensioner 4.8 vortec
https://m.youtube.com/watch?v=qBOdVHS5kcE
Hopefully this link will work. Video of my mystery tap.
my LY2 just jumped time from the same sounds the tensioner pad and the metal peice it attached to was chain slap .Not sure how to load video, but do have tear down video showing broken parts
Old 08-15-2023, 07:09 PM
  #33
Received 3,038 Likes on 2,365 Posts
Originally Posted by JD Haney
my LY2 just jumped time from the same sounds the tensioner pad and the metal piece it attached to was chain slap .Not sure how to load video, but do have tear down video showing broken parts
Jethro hasn't been here for over 6 years. Check post dates.
Old 11-20-2023, 02:48 PM
  #34
dawgs74's Avatar
👆🏻👆🏻👆🏻thats to bad …i was hoping to find out what his culprit was
Quick Reply: Ticking/ tapping noise, help!
