Brand new ls3 block deck flaw need help
Old 03-15-2017, 10:49 PM
ricardo.benin's Avatar
Default Brand new ls3 block deck flaw need help
hi I recently bought a new ls3 block and the block has a casting flaw on deck. Should I be concerned? Also the steel liner looks like there is a gap between steel liner and aluminum casting. Please see pics.
Thanks
richard
Old 03-15-2017, 10:53 PM
Here is pics.
Attached Thumbnails Brand new ls3 block deck flaw need help-img_1962.jpg   Brand new ls3 block deck flaw need help-img_1961.jpg   Brand new ls3 block deck flaw need help-img_1960.jpg
Old 03-15-2017, 11:11 PM
Mechanic a's Avatar
its not uncommon for them to be like that around the liner mine was similar although yours is a bit worse than mine was my machine shop told me it would be fine I would ask your machine shop tho to be safe
Old 03-15-2017, 11:17 PM
eb110americana's Avatar
My crate LS3 had a bit of a gap between the liners and the block as well. It seems the aluminum casting doesn't quite cover 100% of the liner surface as it flows into the mold. I suspect that structurally, it must not be significant, as they probably all have this to some degree--even below the deck where it is not exposed.
Mine did not have the surface imperfection yours has. I am not sure if that is something to be concerned about.
Old 03-15-2017, 11:20 PM
Ok, just curious how much power are you running?
Old 03-15-2017, 11:30 PM
Mechanic a's Avatar
im in the build process now working out compression issues was shooting for 11.5 max and im at 12.4 if I get my quench perfect shooting for 600 to the tire
Old 03-16-2017, 12:06 AM
Thanks for the info, someone please let me know about divot
Old 03-16-2017, 12:20 AM
pdxmotorhead's Avatar
Ive fixed dings like that with high temp metal epoxy. They make it in aluminum for industrial Air Conditioning applications like repairing ex-changers or pumps. Then just use a small block to smoooth it flush.
But usually its damage not a void, one option might be to have someone ultrasound the block just to make sure there are no serious voids in the casting.
Old 03-16-2017, 12:27 AM
I don't think it's damage because every cylinder on that side has the same gap in the same spot, the divot is only on one cylinder.
Thanks
Richard
Old 03-16-2017, 09:53 AM
Block was going to be used in a 700 hp build
Old 03-16-2017, 08:56 PM
1973 STEP A SIDE's Avatar
Where did you get the block from ? I just got one from Summit .
Going to have to look it over real good .
What heads are you going to run ?
Old 03-18-2017, 04:54 PM
No Juice's Avatar
Mine has some of the same gaps on a couple cyinders
Old 03-18-2017, 04:55 PM
No Juice's Avatar
more info on this metal epoxy?
Old 03-18-2017, 05:15 PM
Glad I went and check over my block !!
It will be going back next week !!
Look at how far the sleeves are off !!
Old 03-19-2017, 04:00 AM
Jontall's Avatar
It looks like that block suffers from core-shift... The sleeve thickness varies greatly.
Old 03-20-2017, 07:07 PM
Yeah my cylinders are not bored on center as well like your pics, I found out the gap is from a non square bore
Quick Reply: Brand new ls3 block deck flaw need help
