99TA - 416 build - Stolen, damaged and getting repaired
Old 11-21-2017, 01:51 PM
  #301
lazerlemonta's Avatar
Money shifts...... sigh. I have a good friend that has an LS6 due to some jack *** doing it (points finger at self) Glad she was recovered and at least in tact. A friend of mines LS swapped notch was stolen at mustang week this year....... never seen again
Old 11-21-2017, 02:06 PM
  #302
A.R. Shale Targa's Avatar
Originally Posted by G Atsma
Whoops.... suckers winged it hard and kissed pistons.... OUCH!
Prolly wanna re-CLEAN the driver's seat in particular....guessing their BVDs were unable to contain............
Old 11-21-2017, 02:12 PM
  #303
the car stalled
low manifold vacuum caused this.....
  #304
Received 3,109 Likes on 2,424 Posts
Uhh... if that is even SUSPECTED, the seats are history! Or should be... lol!
Old 11-21-2017, 02:45 PM
  #305
99 Black Bird T/A's Avatar
Received 1,444 Likes on 1,002 Posts
#5 exhaust valve broke keepers off, shed the retainer, spring was stick update against valve cover. Here is what the trashed retainer for #5
Nothing was holding the #5 exhaust valve up and in place other than being stuck in the guide and luck. I'm surprised the valve didn't drop.
Old 11-21-2017, 03:00 PM
  #306
Talk about a lucky break! Could have been WAAAAY worse!
Old 11-21-2017, 05:27 PM
  #307
Received 3,504 Likes on 2,160 Posts
No doubt!! Surely there is a mark on the piston where it got slapped back up?
Old 11-21-2017, 05:43 PM
  #308
^^..which might have bent the valve enough for it not to drop again enough to cause major carnage.
Old 11-22-2017, 10:25 PM
  #309
TransAm P's Avatar
Sucks about the damage but atleast she's back home!!
Old 11-23-2017, 01:26 PM
  #310
JimMueller's Avatar
When a vehicle is stolen and there is damage, is there any recourse through insurance or through legal action?
Old 11-23-2017, 06:23 PM
  #311
Jimbo1367's Avatar
I would think the damage would be covered if you have proper coverage.
Old 11-23-2017, 06:41 PM
  #312
The TA's insurance coverage doesn't cover this sort of issue.
Old 11-23-2017, 10:52 PM
  #313
Moderator
Darth_V8r's Avatar
Received 1,838 Likes on 1,146 Posts
Yeah it would be based off the book value of the car unless you pay through the nose
Old 11-24-2017, 07:20 AM
  #314
On a different note.
Just how tough is a stock rocker with BTR trunnion upgrade?
The thieves that stolen my 99TA mechanically over rev'd the engine so badly #5 exhaust smacked the piston so hard it blew the keepers off the retainer and the rocker stand broke - but the stock rockers is intact. The rocker appears to still be good. It will of course be replaced.
Old 11-24-2017, 09:36 AM
  #315
From reading around here and other places, I do not recall hearing about any stock rocker breaking! So whatever shortcomings the stock rockers have, breaking is not one of them AFAIK.
Old 11-24-2017, 11:48 AM
  #316
LS1Tech Premium Sponsor
tech@WS6store's Avatar
Are you meaning you have those rockers?
Normally ive only seen them crack in the pushrod cup area or seen the pushrod blow through the cup. Ive also seen a few fail at the bottom of the rocker where it goes around the trunion. Ive never seen a aftermarket trunion fail before the rocker from a situation like that though. Very odd that the rail broke though. That really points me to maybe the bolt was working itself loose it seems.
Old 11-24-2017, 10:09 PM
  #317
Yes when I ordered upgraded rockers from Reher-Morrison, they supplied new LS3 rockers with the BTR trunnion upgrade they installed. All these parts are at Norris Motorsports with the TA. I might be able to grab pictures later on.
Yes, it damaged the rocker stand.
Old 12-05-2017, 11:05 AM
  #318
I see five ways to proceed forward.
A) Put the old LS1 back in with the surplus LS6 90mm TPIS intake. Estimated cost $2000 with tune.
B) Fix the top end of the ERL 416. Heads have to go back to Reher-Morrison. Estimated at $2500 to $3000 may need new cam, new lifters & rockers etc depending on what's found.
C) Pull the ERL 416 and check everything. Fix top end as above. Estimated at $4500 to $5000
D) Scrap the 99 TA and part the car out. The Hawk's 8.8 rear end can go to my girlfriend's son's and the T56 Magnum and carbon fiber drive shaft to the white RS.
E) Pull 416 to make sure it's right and go LLSR since I will likely be buying another cam and lifters. What does a LLSR cam, good lifters & adjustable rockers typically cost?
Previously I was anti LLSR cam for my 99 TA since the car was a daily driver. Going forward the car will be insured as a classic / specially car limited to 3,000 miles a year. A 4th garage space has been secured for the 99 TA. Since the car won't be able to see 15,000 + miles a year anymore - I no longer have an objection to putting an LLSR cam in the car - even if the life expectancy is only 30,000 miles or so.
I'm pretty sad the TA can't be a daily driver anymore regardless of how this goes forward.
Old 12-05-2017, 12:32 PM
  #319
I would keep the trans am.
An llsr with rockers runs about 1k+. $359 for the tie bar morels. $389 for cam. And adjustable rockers run in the $500s+
You can use stock rockers but then pushrod length is that much more crucial and has to be measured and special ordered. Then you want make sure you get the right wipe pattern and shim rockers if not correct.
Why are you questioning the lifters? I understand you want piece of mind, but there is also a line between being cautious and overthinking.
What on the heads needs to be fixed besides the bent valves?
Old 12-05-2017, 02:12 PM
  #320
I appreciate the info on the LLSR and it's cost.
Motor isn't cracked up yet so other than bent valves and other Val e train stuff hopefully not anything else wrong with heads. With cylinder #5 the exhaust valve stuck at the top the cam is smacking the loose lifter. It's audible now that the exhaust leaks are tightened up up in the y pipe etc. The lifter roller and cam lobe maybe buggered from smacking. Since LS7 lifters are like $100 a set I really can't see reusing these since the heads are coming off.
Quick Reply: 99TA - 416 build - Stolen, damaged and getting repaired
