It had to happen.
Old May 14, 2017 | 01:27 PM
  #101
Darth_V8r's Avatar
Moderator
Originally Posted by big hammer
DarthV8r switched from hydraulic to LLSR. But his stock 10 bolt with 3.42's blew before he could hit the dyno. So even with a new 9" with 4.10's he still gained RWHP.
Yup! I NET gained 14 after LLSR, nine inch , 4.11 gears and 28" tires.
Martin Smallwood speced my cam. Iirc he and Kip co-designed the LLSR and Martin has his own proprietary lobes. IMO. He nailed it.
Old May 14, 2017 | 01:57 PM
  #102
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
I forgot about that one completely. I noticed Tony like Comp Cams sticks. I'd love to see him build a street stroked LS3 with his 235s/FAST/LLSR. That would be a blast on the street.
Jimbo,
you may get close your wish, I know a member here considering
MMS 235s for his 416" build for his trailered drag car, don't want
to give up to much of his combo, its in the planning but pretty
sure it will have a LLSR.
On another note Pretty sure we will see a 416" with MAMOFIED LS3s and comparison between long & mid-length runners on a FAST also.
Old May 14, 2017 | 02:29 PM
  #103
big hammer's Avatar
Originally Posted by NAVYBLUE210
Jimbo,
That would be some interesting results
Old May 14, 2017 | 03:04 PM
  #104
Tuskyz28's Avatar
Ever notice how Tony likes to use "PS" alot? LOL. Thanks for the read and link Tony @!!!
Jimbo,
Member really needs to go with 250cc MMS intake runner espically since a solid roller go be in place...
Solid Roller & High revving= milk n cookies
​​A 416ci motor has enough bore to make magic happens in my opinion. Encourage him to go 250cc!!
Ive seen Richard Holdnerer take a 408ci motor with AFR 245s out the box and make 630 hp with small headers and pump gas compression (11.0:1).
Also remember the discussion we had about 20 LS intakes tested article in Hot Rod Magazine.... Richard made 592 horses with a Fast intake with AFR 230s out the box on top of a forged 6.0 motor. It did well!!
Old May 14, 2017 | 03:21 PM
  #105
Member asked Tony 250 or 235, Tony said 235 W 2.10" Intake Valve,
In this instance I concur with Head designer.
Old May 14, 2017 | 05:40 PM
  #106
Tuskyz28's Avatar
Tony was drinking at the time and clearly didnt understand the conversation.
​​​​​Why put a 235cc head on with a SOLID ROLLER setup thats go turn 8500 rpm or so? It doesnt makes sense at all.
Now a 250cc head will give the motor room to grow down the road. 235cc runner go be DONE at 7400 rpm max while the 250cc still go be breathing in my opinion. Must I remind you I spoke with a guy thats respected just as much as Tony in the LS community and ge says otherwise. Also he dyno/tune cars and spec cams for a living all day everyday so he sees all kind of powerbands on different builds.
Old May 14, 2017 | 08:50 PM
  #107
Jermaine
Whoa,
Take a long slow deep breath, pause, count to 10 as you slowly Exhale,
Repeat.
Couple points to consider.
1. This is his build, not mine or yours.
2. He has assembled and built several LS Engines successfully,
I have not assembled an engine and I do not believe you
Have either.
3. He has no desire to spin 8500 RPM or even 8000 necessarily,
I believe he would like peak HP~7000RPM & shift @ ~7500 RPM.
4. A 2.10" intake valve is ideal for a ~4.070" Bore IMO.
If I was going to a 2.165" Intake Valve I would go to the
AFR LS3 260 rather then a 250 CC Cathedral but that's
Just me.
Old May 14, 2017 | 09:14 PM
  #108
Darth_V8r's Avatar
Moderator
For 8500 rpm I'd be thinking rectangles. Whoever it is you're talking about I'm sure is very very good at this stuff. But I'll take Tony's word over "a guy who is just as respected and also does this for a living". Be honest. If I was telling you "a really respected name in the LS community" and not a name you'd be calling me out like crazy. Or trashing the guy because you don't know who we were talking about. Or both.
Now if you're gonna say Ed Curtis or Brian Tooley I hear you and they are well respected. I've held off on this post because I don't want to come across like I'm trashing an engine builder - which I'm not.
But I think Tony knows his own heads and their capabilities quite well.
Old May 14, 2017 | 09:41 PM
  #109
Tuskyz28's Avatar
Jermaine
Whoa,
Repeat.
Have either.
Just me.
​​​​​If he's not go rev the engine past 8000 rpm... why the hell go solid roller ?
1. It costs more money to go soild roller.
2. You mentioned the car go spend more time on the track than the street.
3. If 2.10 was better suited for 4.070 bore... why would GM put a 2.16 on smaller bore motors from the factory.
4. The AFR LS3 heads are not PROVEN performers yet.
5. It dont makes sense to me neither putting a square port head on a 388ci with a hydraulic roller neither.
DarthV8- the guy i spoke to is actually a guy that know how to spec cams to any head!! Period. Ive seen him make a afr 205 head (402ci) trap 130 in a 6 speed car that was nearly 3800lbs with the driver. When i say hes respected.... its a understatement.
Must i also mention he have helped guys get over 500rwhp on stock bottom end ls1 cars.... f bodies at that..
Old May 14, 2017 | 09:52 PM
  #110
big hammer's Avatar
I thought Darth has one of the highest hp stock bottom end ls1's
Old May 14, 2017 | 10:00 PM
  #111
i thought darth has one of the highest hp stock bottom end ls1's
Touche'
LOL!
Old May 14, 2017 | 10:17 PM
  #112
Darth_V8r's Avatar
Moderator
No it does not. Solid roller morels are $400. Shims are $125. Cam is same price as any cam. You don't need adjustable rockers. Cheaper than a short travel hydraulic Johnson set up.
I really wish you'd get over that. Not every car is a purpose built track car. I wish mine could see the track more often. If it could it would run a lot better. But I travel like crazy so I can't get it to the track. But the default position of "doesn't count since it wasn't at a track" is not applicable to many cars.
agreed.
That sounds like PatG, and he is very well respected and I'm not at all trashing him, and I thought I was clear on that point. And to do that with a 205 head was absolutely impressive, if not altogether groundbreaking. And if memory serves Tony and Pat worked together on that one. Unless I'm confusing it with a different build.
What I was responding to was "Tony must have been drinking...". I'd advise calling Tony up to understand why he said it first.
  #113
Tuskyz28's Avatar
http://www.superchevy.com/features/ghtp-1111-2002-camaro-ss-simple-plan-wicked-results/
Why dont yall guys take notes? 520 rwhp on a stock bottom end with a fast 102mm intake and hydralic roller threw a AUTOMATIC 4L60E with track numbers to prove that it hauls ***!!
Again... this S#it is not rocket science to pimp with Tusk.
Old May 14, 2017 | 10:18 PM
  #114
big hammer's Avatar
Happy dynos are happy
Old May 14, 2017 | 10:23 PM
  #115
Darth_V8r's Avatar
Moderator
Link not working. That Chris Johnson (chrs2313)? I remember he got very low tens at one point H/C.
Old May 14, 2017 | 10:27 PM
  #116
Tuskyz28's Avatar
So is the drag strip!! Thats why the car went 10.0s @ 130 mph plus.... a wise man told me talk is cheap and results is what matters! So.... lets go race your Huffy bicycle against my 21 speed Mongoose.
Old May 14, 2017 | 10:33 PM
  #117
Tuskyz28's Avatar
Yeap thats him.... according to Dan and Big Hammer you need a MSD intake Mamofied with a solid roller to clear 500 rwhp!!
Old May 14, 2017 | 10:39 PM
  #118
big hammer's Avatar
Cool we're into strawman arguments now. Nobody said that.
Old May 14, 2017 | 10:42 PM
  #119
Darth_V8r's Avatar
Moderator
You don't but it is easier for sure. I don't see them saying that though. But it is how I got it done.
Old May 14, 2017 | 10:46 PM
  #120
big hammer's Avatar
I don't see the point of going through the process of making a hydraulic act like a solid when you can just use a solid. Unless you're class limited
