Camshaft question
Consider Comp Cams.......you can go to Comp with the intent of getting a cam with, say, a 224*/234* duration. HOWEVER, given the fact the Comp has like 12 'families' of lobes to chose from, you could end up with 12+ different cams.....all with different performance characteristics and requirements that will give you 12+ results.
And that's just within that ONE brand.
What you really should consider is contacting one (or more) of the several cam 'experts' on this Forum, telling them exactly what you have and exactly what you want regarding your car, and letting them spec you out a cam that would best support your setup and your goals!
IMHO, of course.
Cam Motion, Tick Performance, Brian Tooley Racing, Pat G., etc.
If you're dead set on your specs.....I recommend contacting Cam Motion and having them cut the cam for you.
KW
If you want to email us with more info, we can get you all set up with a camshaft made for you, whether off shelf or custom grind for the same price!
Rpmspeedtech@gmail.com
Cam motion probably has the most loyal following on here. And I've seen more and more of the cam experts who spec them for a living turning to cammotion.
I'm very partial to cammotion. There are lots of guys who are. My first experience with them they bailed me out of a jam when my cam was ground 9 degrees off (different vendor). And they were very instrumental in developing the low lash solid roller. They also place all their cams on a cam doctor after they are ground and send you the actual measured cam report, not just the spec card.
Anyway, there's one man's experience
Its pretty much who is the flavor of the week.
For your next purchase, we hope you will consider Cam Motion. We have been manufacturing championship winning camshafts for 40 years. From the current defending and 3 time NHRA Top Fuel Champion Antron Brown and multiple NHRA Pro-Stock champions, to countless hotrods and street cars, we have worked hard to achieve our reputation for quality, performance and reliability.
Here are a few reasons to consider Cam Motion for your next camshaft:
- 40 years of Championship Winning Experience
- Superior 8620 Steel Camshaft Cores
- Quiet, Smooth & Powerful Lobe Design
- Virtually Unlimited Lift and Duration Combinations
- Polished Lobes For Quiet Operation
- Cam Doctor Printout to Assure Accuracy Provided with All Cams
- The Industry's Best Customer Service
Top engine builders and experts use Cam Motion mainly because of the quality of the product and the customer support. We work hard every day to make every customer a raving fan. I hope we can earn your business when you are ready to purchase your next camshaft.
~Steven
