Help, needle bearing needle in oilpan, not lifter or rocker
Any idea where this needle could be from, friends car and found it during oilchange. 12.5mm long and diameter 2.2mm so i thought it is from lifter, but no, all were good.
Where could it be from, no any previous lifter etc damage in engine.
Pic attached...
Pic attached...
The only needle bearings are in the rocker arm trunnions and some lifters...I think.
Does the drain plug have a magnetic tip? He could of picked up something from the ground or shop table during last oil change if it is magnetic.
