Before and After TFS Porting
Old Jun 1, 2017 | 03:19 PM
Frankenstein's Avatar
Default Before and After TFS Porting
Here's a look at how we receive our TFS castings and what they look like after port work.
For those that don't know we receive them in a porter's casting (raw), and then run our port program through the heads which you'll see in the second image.
For anyone looking to upgrade to a set of TFS cylinder heads with the Frankenstein port program in the cat port version, we have two options.
TFS 237cc = $2900
TFS 254cc = $3250
-Russ
Old Jun 1, 2017 | 03:43 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
I wasn't clear, re read and understand
Old Jun 4, 2017 | 04:39 AM
07NBSChevy's Avatar
Do you have before and after flow numbers on say, 243 heads or any heads for that matter. I would really like to see the difference porting makes compared to stock.
Old Jun 5, 2017 | 11:30 AM
07NBSChevy,
Here you are:
BEFORE AFTER
Int: Int:
0.100 = 61 0.100 = 66
0.200 = 127 0.200 = 127
0.300 = 188 0.300 = 226
0.400 = 230 0.400 = 263
0.500 = 250 0.500 = 294
0.600 = 256 0.600 = 304
0.700 = 240 0.700 = 309
Exh:
0.100 = 50 0.100 = 56
0.200 = 104 0.200 = 108
0.300 = 140 0.300 = 150
0.400 = 162 0.400 = 176
0.500 = 170 0.500 = 208
0.600 = 177 0.600 = 221
0.700 = 182 0.700 = 228
-Russ
Old Jun 14, 2017 | 11:45 PM
jlrz28's Avatar
10 Second Fun Car
Any flow numbers on the 237cc? My 215s have been great from TEA (5+ years) and man the numbers still amaze me. Just always curious what a bigger head would do on my current setup.
Old Jun 15, 2017 | 08:12 AM
Intake Volume 237cc
Exhaust Volume 83cc
Chamber Volume 65cc
Intake Flow 292cfm @ .400”
348cfm @ .700”
Exhaust Flow 218cfm @ .400”
255cfm @ .700”
PAC spring kit included good to .700” lift
Intake Valve Diameter 2.080”
Intake Seat Material Ductile Iron
Exhaust Valve Diameter 1.600”
Exhaust Seat Material Ductile Iron
Valve Angle 13.5
Valve Guide Material Bronze Alloy
Minimum Bore Size 4.030”
Old Jun 16, 2017 | 04:03 PM
TrickFlowTech's Avatar
LS1Tech Sponsor
Nice work guys!
__________________
Old Jun 17, 2017 | 01:00 PM
joyridin''s Avatar
So, if we take a set of Trick Flow heads that Trick Flow CNC ported and compare them to yours, what differences are we looking at?
