LS7 aftermarket rods?
Old Jul 13, 2017 | 07:29 AM
RPrezas's Avatar
Default LS7 aftermarket rods?
So long story short, dropped a valve, very minimal damage but I am going to get my block re sleeved. I want to get rods and pistons, so my question is, the pistons I want require the 6.125 long rods. Will that rod and piston set up work fine with the stock ls7 crank?
Old Jul 13, 2017 | 07:42 AM
KCS's Avatar
KCS
Moderator
It'll work, but it's going to cost s lot of money to balance the crank since the steel 6.125" rods are so much heavier than the stock titanium rods.
Old Jul 13, 2017 | 07:47 AM
RPrezas's Avatar
Cool, I just want to make sure the motors geometry will be fine. I don't wanna get surprised with a piston sticking out at TDC. Thanks!
Old Jul 18, 2017 | 04:53 PM
Hodgdon Extreme's Avatar
At GM Racing, first thing we'd do for a racing engine that started life as an LS7 was to replace the Mahle Titanium rods with Carrillo steel H beams.
Crank balancing would require quite a bit of tungsten...
Old Jul 18, 2017 | 10:39 PM
Pankl has supplied those rods for the last few years. They are super light, super expensive (when bought new) and brittle. I'd rather have steel vs. ti rods personally.
Old Jul 18, 2017 | 11:00 PM
I was there ~2008; no idea what the LS7 has now. I know for certain though, that Carrillo is never the wrong answer!
Old Jul 18, 2017 | 11:25 PM
Crf450r420's Avatar
Callies Billet rods are a good way to keep the weight increase in check.
Old Jul 20, 2017 | 12:19 PM
pantera_efi's Avatar
Default LSX + LS-7 Dry Crankcase
Hi, my "data", LSX Block with LS-7 "long snout" crank (needed) for LS-7 Dry Sump Pump.
Crower Billet Rods with .990" pins.
RaceTec Pistons. (lite)
MY Mallory cost was $800.00 with total balance cost OVER 1K.
Thus a LOWER cost to fit a Steel Crank with 1850 BW. (Long Post)
There is a know fact that the GM Ti Rod is GM rated for 500 HP.
Lance
