Differences between 4.8 models? LY2, L20
Compression is listed as...
LY2 - 9.1:1
L20 - 8.8:1
If the only difference is the 61.15cc head VS the 64.45cc head? Do the use the same pistons, blocks, rods, head gaskets etc? So 3.3cc of CC is only dropping compression .3?
Every gen 4 4.8/5.3 with flat tops came with 799/243s
The Engines are identical- Block/Heads/Intake Manifold/Crankshaft/Connecting Rods/Piston Rings, with the exception of;
-Pistons (for VVT)
-The cam (for VVT)
-Timing cover (for VVT)
-Cam sprocket (for VVT)
-Intake valves (for E85 Flex Fuel)
-Valve covers (Older design was used on LY2)
-Oil filler neck
-Oil pan (different shape, same capacity of 6 qts.)
-Injectors for flex fuel.
-MAF Sensors, Airbox, and Intake tube (MAF Sensor location changed)
2007.5-2009 Silverado LY2 4.8L
-No VVT
-9.1:1 Compression using 0cc Flat Top Pistons
-295-Hp at 5,600 rpm, and 305-Tq at 4,600 rpm
2010-2013 Silverado L20 4.8L
-Has VVT
-Flex Fuel Capable
-8.8:1 Compression. The lower compression, compared to the LY2, is due to the added valve reliefs cut into the pistons for the VVT using -3cc Flat Top Pistons
-302-Hp at 5,600 rpm, and 305-Tq at 4,600 rpm.
Thought I what list all the differences in the two engines just in case, and yes...the valve reliefs are the only reason for the compression difference.
