RPMSpeed Ported Hi Flo ls pumps (with pics)
Even though summer ends today and our Summer Sales Special is at an end, we are extending the special through the weekend. Pm, comment or email and we will get you set up!!
The gasket kit prices are good til the end of this yr also.
We have 15 pumps on hand ready to ship.
The M295 is a cast body pump and very similar to our pump BUT our ported pumps are obviously ported, but also include checking clearances inside the pump and making sure the cover is flat machined and also have low clearance bolts on the front cover to help with running dual roller setups.
We can also shim our pumps for higher bypass pressure and may offer them in a higher volume option soon. The std non ported pumps also use the same low clearance bolts and precision machined front and have shown 0 issue with needing any grinding vs a few of the other cast body pumps.
We may be offering other options soon but that's it for now. Plus our pump is less than some sell the reg m295 for.
The 10295 and 10296 are a higher quality pump than the rpmspeed pump is in quite a few ways so there is no comparison there.
#33
I'd like to report that I have the new motor in the car with the RPM ported pump and upon initial startup oil pressure was at a very impressive 58-60 psi cold and 38-40 psi fully warm at idle. While driving I'm seeing 58-60 psi at around 2000-2500rpm's. Very happy with the pump so far and feel confident that it will keep up with my 7200 rpm shift points on nitrous. Should also mention Im running Lunati 10-30 break-in oil with the Improved Racing pan baffle.
#34
