Btr stage 4 ls3 piston to valve clearance
Is a miss as good as a mile??? lol
If you are getting new heads, then the clearance you are asking about would not matter anyhow. If you are concerned about the clearance, you need to check with the new heads.
My engine is basically stock and it clears.
I guess I worded my question wrong lol. Does it clear enough to feel comfortable with stock heads? If so id feel more comfortable about it going with a set of the ls3 Trickflows with the 12 degree valves because that should allow for even more clearance shouldn't it?
Location: Coast of San Mateo County Between Pacifica & HMB
Terrible!
+12* is plenty NA with a good exhaust system.
I used +6* exhaust split with TFS LS3s
Talk with Cam Motion for a much better cam.
Just my opinion ....... and experience.
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
