Is my block trashed?
The ones I've seen done were done on a CNC mill and were hard to get blocks...
Didn't you RECENTLY find a crack in your block? I am thinking trhis post was before that. Best of luck to both of you.
starter breaks
https://ls1tech.com/forums/general-m...ock-broke.html
The stronger truck starter can't break off like this bevause the inboard mount is stronger using the longer bolt.
Actually GM should have updated this but never did!
You can find the updated starter : http://cgi.ebay.com/ebaymotors/New-S...Q5fAccessories
read carefully it doesn't include the longer bolt, this will stop the broken block problem.
This one includes the longer bolt http://cgi.ebay.com/ebaymotors/Start...item53e0021caf
All ls1 engines should use this stronger design but if you plan on doing ANY mods to the engine this should be your 1st one!
I read they offer a replacement bolt, a longer bolt for the starter to "fix" the issue also?
Could be for other LS blocks, just fwiw
