Lifter Preload Inconsistencies
L76 6.0 truck motor, stock bottom end, 218/226 629/603 113+3 cam, ls7 lifters, 660 lift double valve springs, stock rockers with trunion upgrade, 7.4 pushrods, l92 heads milled .010, stock l92 head gaskets, stock valves.
I checked my lifter preload on cylinders 2, 4, 6, 8 with a pushrod length checker and this is the preload values that I came up with.
Cylinder 2 - Exhaust=.100 Intake=.075
Cylinder 4 - Exhaust=.100 Intake=.0875
Cylinder 6 - Exhaust=.094 Intake=.060
Cylinder 8 - Exhaust=.112 Intake=.075
I haven't had a chance to check cylinders 1, 3, 5, and 7, I will check them after work. My main question is, why is there such a large gap between exhaust valves on cylinders 6 and 8 and intake valves on cylinders 4 and 6? I plan to get some 7.375 pushrods for the exhaust valves, unless y'all would recommend going with custom push rods from Manton. Thanks for the help.
Once you do the that's, add the amount of preload you desire to that length for ordering. What is the longest and shortest measurement?
