Oil temps too low?
Old Sep 14, 2017 | 05:12 PM
HOONIGAN's Avatar
Default Oil temps too low?
Good Morning, hope I'm in the right section. I have a 6.0 iron block stroked to a 416ci.
Parts Used:
-block is half filled for extra strength, and sonic tested
-balanced machine bored, honed, decked, line honed, hot tanked, etc.
-diamond forged flat top -2cc pistons
-total seal AP steel nitrous rings
-eagle H-beam rods w/eagle ARP Rod bolts
-trend think wall wrist pin .927 x 2.50 x .225
-Callie's Dragon Slayer 4" crank with tig'd trigger wheel for extra strength
-ARP pro series main studs
-ARP crank cap bolts
-LS6 intake manifold
​​​​​​-243 heads
-external oil cooler
Before the oil cooler it was running 260-270*, now after the oil cooler its only getting up to 110-115*. How bad is it for the motor, it's freshly built, is there a good way to fix this? Has anyone heard of this problem? I cannot find any info on anything like this.
Old Sep 14, 2017 | 05:33 PM
Run a thermostat in the circuit.
Old Sep 14, 2017 | 05:41 PM
00pooterSS's Avatar
Smartest tech I ever met said he got to speak to an petroleum engineer about oil and the engineer said oil needs to be at least 140 degrees to lubricate properly.
A little helpful but doesn't necessarily state a minimum temp but does say your temp is too low.
http://www.hotrod.com/articles/engine-oil-temperature/
Old Sep 14, 2017 | 06:45 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
Oil temp should be 160*-170* Minimum, Ideally 190* before WOT.
Old Sep 14, 2017 | 10:41 PM
Agree with Navy. Modern engine oils are designed to provide maximum lubricity at 200 degrees. As stated above, you'll likely need an inline oil thermostat.
Old Sep 14, 2017 | 11:10 PM
tadams72's Avatar
Improved Racing makes a nice thermostatic valve. You definitely don't want to run the engine much with that oil temp. Not only for lubrication but also because an oil that doesn't come up to sufficient operating temperature will not boil of water and condensed gasses. This creates a separate problem of caustic chemicals that can wreak havoc on an engine.
Old Sep 15, 2017 | 12:01 PM
pantera_efi's Avatar
Default Block Temperature
Hi Hoon, I was part of the JTD test shop used to certify items for the Viper.
ONE test was block temperature/ring wear.
WE FOUND that a block water temperature of under 160F would CAUSE Ring Wear to increase by 1600%.
The NEXT question about the Oil Temperature requirement : OVER 212F allows for the Water Vapor to be extracted from the oil.
This if not done, the "cold" oil is seen as Mud, creates Brown Oil.
Lance
Old Sep 16, 2017 | 01:19 PM
Dan99Hawk's Avatar
I disagree with all of that ^
In the marine world, where engines are sea water cooled and we use oil stats to warm up the blocks oil temps and blocks temps are very low.
My water temp gauge never moves, always under 100* since I`m taking in 70* water. Rings are fine.
Most Mercury engines from factory and everyone else runs oil temps in the 150*, no issues.
My oil temp is usually around 140* in both motors , 900 hp , usually at 4-5k rpm for miles . Motors have been apart no issues. Bearings look great.
Oil won`t burn off condensation unless it`s 212* is an old wives tale.
Old Sep 18, 2017 | 05:35 PM
00pooterSS's Avatar
Apples and oranges. You said you use an oil thermostat therefore the correlation between water and oil temp on your setup is null. On his application it isn't.
Do you have any literature on testing that shows oil doesn't need to be at 212 to burn off water? I'd like to know how the condensation converts from a liquid to gas state without reaching the boiling point. I'm being serious, not a dick, looking to learn not have a pissing contest.
Old Sep 18, 2017 | 05:56 PM
Dan99Hawk's Avatar
Not really apples to bananas, I use oil stat to bring the oil temp up. In the end I end up with 150*oil and 100* water temp.
So then according to the 1600% increased ringwear theory my engine should be shot after one weekend?
Put water on the stove at a 150* or even in the sun on a hot day..it still EVAPORATES. It only BOILS at 212*
My Current GS runs 160* oil temps in the winter and 180* in 80* summer weather , only once on a hot day in stop and go traffic have I seen it hit 200* . If water didn`t EVAPORATE at lower temps Id have a milkshake in the motors but I don`t. GM engineers don`t think 212* oil temp is necessary.. I agree.
Old Sep 18, 2017 | 06:18 PM
^^^^THIS!^^^^^ It's evaporation that is needed, NOT boiling, though it is OK too. You splash water on a 100deg. sidewalk, and it flashes off QUICK!
Old Sep 18, 2017 | 11:26 PM
Brons2's Avatar
My fiance thinks your boat engines are very pretty. Lol.
Old Sep 19, 2017 | 06:55 AM
Dan99Hawk's Avatar
My wife says me too!
Old Sep 19, 2017 | 10:21 AM
00pooterSS's Avatar
I work on cars all day every day and have since 97, I see plenty with milkshake on the bottom of the oil cap but it's not inches deep, it's just a coating. And they go down the road for forever. So yes motors roll on for long times without burning off/evaporating off all the condensation/moisture/water. So running below 212 is okay apparently, but running above 212 likely burns off MORE condensation and I think that was the point of people recommending to stay above 212. And oil likes to be at that temp, so why would you not target that range if you're going into the system and going to put a thermostat in it.
As for apples and oranges.. an application with an oil thermostat vs an application without cannot be compared if you want to compare oil temps of both, relative to water temp.
I agree with all about the difference between evaporating and boiling. My question about burning off the moisture was about burning it off aka boiling, not evaporating. But I get y'all's point and agree.
Old Sep 19, 2017 | 11:17 AM
While lower-temp evaporation is OK, higher temp "boiling off" (actually just faster evaporation) would be best for oil purity and function. Dan99Hawk's argument above really does not hold water. Those marine situations are examples of "barely getting away with it".
Old Sep 19, 2017 | 11:50 AM
00pooterSS's Avatar
Old Sep 19, 2017 | 09:14 PM
Dan99Hawk's Avatar
I`m not going to argue obviously higher temperature oil is better and then it actually reached it`s full viscosity as it is measured at 100*c or 212*f.
lower temps are definitely not even remotely "barely getting away with it" as every marine engine runs cold oil temps and hardly any water temp,.
Here`s my Grand Sport after a 1 hour highway trip in the winter. Them GM engineers sure are just barely getting away with it I guess lol
Old Sep 19, 2017 | 09:18 PM
Just because it is happening does not mean it's good for it. Where are you located?
Old Sep 19, 2017 | 09:36 PM
Dan99Hawk's Avatar
lol it`s not bad for it either.
I`m in Chicago.
Check out the 2.33 mark. Second gauge from the right is my oil temp. (153*) Those are endurance engine. No gears , at 4000rpm I`m making 4lbs of boost and probably 600hp just to keep the speed at 60mph. Lots of load, lots of stress. I do this every weekend in the summer.
If the wives tales were true I`d have to change my oil every weekend due to condensation and my rings every year, lots of blow by etc etc . That`s simply not the case not even with a pair of 900 hp endurance engines
Old Sep 20, 2017 | 11:45 AM
00pooterSS's Avatar
You keep knocking the info in this thread while showing oil temps at a minimum of 140 degrees, my first post said oil must be at a minimum of 140 degrees. You also keep referencing water temp vs oil temp yet you have an oil thermostat....
"marine engines run cold oil temps and hardly any water temp" really? my chevy small block in my boat runs at 170-180 degrees. Right where it has for the last 27 years.
