DOD/AFM delete help
Old Sep 24, 2017 | 01:52 AM
Tieler Dobbins's Avatar
Default DOD/AFM delete help
i have a 2013 Silverado 5.3 LMG. I have no idea which delete kit to go with. On top of that I would like a higher performance cam but still low lift so I don't have to rebuild the heads. Input?
Old Sep 24, 2017 | 09:58 AM
Call WS6store, a sponsor on here. They will get you all lined out, and with good prices.
Old Sep 24, 2017 | 10:04 AM
silversweetZ's Avatar
Second on WS6 store....Texas Speed has a kit as well. I've got the front of my 06 Envoy tore apart right now troubleshooting a low oil pressure issue (found pickup tube o-ring split) and i'm trying to decide to pull the trigger on the DOD delete or not. Been doing the research as well. Good Luck
Old Sep 24, 2017 | 06:15 PM
i took a minute and went to the ws6 website. All they offer is the seal and lifter kit. What is a nice low lift performance cam for the money? And the Texas speed sight, for some reason it gives me 3 different cam options but I can't even read what they are.....
Old Sep 24, 2017 | 09:43 PM
Call them up. Their website is a bit awkward to navigate, and doesn't show everything they have. They DO have what you need. Are you going online with a phone or computer?
Old Sep 24, 2017 | 11:32 PM
blk00ss's Avatar
Turn your phone sideways and click on each option. It pulls up that way.
Old Sep 25, 2017 | 11:38 PM
CattleAc's Avatar
i have a 2013 Silverado 5.3 LMG. I have no idea which delete kit to go with. Input?
PM tech@WS6store, he'll steer you straight. I got all my DoD/AFM delete stuff from the WS6store. He did a good job of getting me everything I needed when I did mine.
Old Sep 25, 2017 | 11:45 PM
CattleAc's Avatar
I just reread your post...I went with TSP's Stage 3 truck cam. I used PAC 1218's. Didn't touch the heads...
Old Sep 26, 2017 | 12:04 AM
TSP's truck cams, except for the smallest one, give you a choice of either .550 or .600 lift. Neither requires rebuilding your heads, just a good set of springs (PAC 1218's work great)
Old Oct 10, 2017 | 07:45 AM
David@Vengeance's Avatar
Our DOD/AFM delete kit coupled with our Budget Cam Kit will square you away with most everything needed for a full install on something small.
https://vengeanceracing.net/1999-tra...elete-kit.html
https://vengeanceracing.net/1999-tra...t-cam-kit.html
Our VRX1 camshaft (220/220 .581/.581 114+4) actually works very well with the spring/pushrod combo we offer in the budget kit to keep a near-stock sound with a bump in performance.
Feel free to reach out if you have any questions!
- David @ Vengeance
Old Oct 10, 2017 | 11:39 AM
2xLS1's Avatar
All of Brian Tooley's truck cams will work with LS6 springs (cheap). All you really need to delete AFM/DOD is 8 standard lifters and a non DOD cam (stock) or an aftermarket cam and springs and of course the PCM tune changed. I work with a machine shop here that does about 10 DOD deletes a month and all they change is the cam to a stock non DOD 5.3 cam and lifters. They don't change the valley cover unless the truck is having a low oil pressure issue.
