5.3 CMP issues. Everyone stumped.
After some investigation, it doesn't have the original 5.3. I know this because it had a dipstick in the block, instead of in the envoy pan. I know nothing about the donor engine, and cannot access the build codes on the back of the engine due to space constraints in the envoy engine bay.
After fixing that profound issue, of a huge oil leak, it has a Camshaft correlation code.
Tech 2 shows CKP functions fine, scope shows the same. CMP however is taking erratic events, and rpm jumps all over the place. Scope for CMP looks good though.
Pulled timing cover, confirmed in time, replaced all sensors 2x, replaced ECM, wires ring good, no shorts, no grounds, trouble still present.
Hard starts/backfires on first start attempt, 2nd attempt engine starts but performs sluggish. This is due to the 180 degree swap the ECM does every other cycle when the CMP is unable to be confirmed.
Now starts the fun. The CMP is/was contacting the cam gear. Physically. Added washer to space it out for testing, still no help.
Senior tech at GM was sourced, and he followed all steps I have, literally, and confirmed everything is in order. Sensors, wiring, ecm, etc.
Tech @ GM started looking and discovered that the part numbers between a envoy 5.3 and truck 5.3 do not match as far as timing cover, and timing set. Sensors are the same.
Before I tear this timing set off and replace it, does anyone believe there is a difference in the cam gear for the envoy 5.3 and a truck 5.3? It leads me to believe maybe the envoy timing cover is compressed, and the gear may be thinner or something similar, leading to the fact that the envoy timing cover is allowing the CMP to strike the reluctors on the cam gear. I am assuming the donor engine came from a truck, and the envoy pan and cover were sourced from the original engine.
Any, and I mean any help, would be appreciated.
Signed,
3 payments in, and still haven't drove it.
if it has a 58x crank reluctor, it should have the matching timing gear.
58 x crankshaft reluctor wheels.
No cam reluctor machined into camshaft.
Cam sensor moved to front timing cover.
Camgear used was "type A" 4 x signal below and held on by 1 large centre bolt.
My question I guess is, is there any possible way, seeing as how GM lists 2 different part numbers for the same year, same VIN, 5.3, in a truck, and in the envoy, that there might be slight differences?
I know I have a E68 ECM, and the trucks use a E37, but I can't figure out why the sensor is contacting the cam gear.
Once again, leads me to believe I have a truck motor, with an envoy timing cover, and that's where my problem may be??????? The physical spacing of the sensor is different or the size of the gear, or both may be different for the Envoy VS. Truck..?
Do you know if in fact that is what is in your Envoy?
Does it have VVT? (you never said...) The LH6 does not have it. You would have seen it when the timing cover was off. I doubt the VVT timing gear would fit inside a normal timing cover. BUT if it does, that would explain the sensor hitting the gear.
http://cliff.hostkansas.com/pffimage...g_cover_04.jpg
Sounds like the cam is messed up or there was no cam retaining plate installed. Either way I'd think you would have destroyed lifters by now.
If it's the original ECM and a different engine, this would need to be done.
However, this does not explain an erratic CMP signal.
Checking the harness wiring and try to backprobe the CMP with a multimeter to see if it is getting a continuous source of voltage, the ground is ok, and check the signal it produces.
Yeah, try the case relearn. See what happens.
