LS3 with LS7 heads - valve relief question
No, I'm not selling them and going with a LS3 head.
My question is, if I buy aftermarket forged LS3 or L92 pistons, will the valve relief positions in a LS3 designed piston give me hell with the LS7 valve placements?
If I go with standard "rebuilder" hyper pistons, then I'd pick the L92 since they will have valve reliefs, but will they still be sufficient to clear the LS7 valves?
I'm going to be running the GM LSX454 cam because it's free and a decent choice for my 2005 GTO street car build - 236/246 @ .050" and .648"/.648" lift (LS7 1.8 rockers) on a 110 LSA. So I'm certain I'll need some sort of valve reliefs.
Thanks,
Cole
Also here's 1 again......Ls7 heads on a Ls3 Camaro with factory pistons. Mag has more reading but the pic's tell it all...little fly cutting of the pistons .080 intake and .070 exhaust. .629/.620 cam lift no duration listed. I have the mag.
http://www.superchevy.com/how-to/ght...r-heads-ls7up/
I was going to see if I could turn the OD of the stock LS7 valve down from 1.615" to 1.590" in the lathe. I know it will narrow the seat width of the valve a little bit (.0125" on width), but I'm sure it would seal just fine.
The big question mark is what it will do to the flow. I'll put it on the flow bench and see how much the two sizes change flow with a 4.070" bore and go from there. I wonder if it won't improve the flow a little by unshrouding the valve from the bore a little.
Thanks,
Cole
