what crank wheel do i have 24x or 58x
i have a 2007 sierra 1500 with a 5.3 DOD motor.
i believe 2007 is a transition year where i could have both the 24x ring or 58x
is there any way i could tell what crank wheel i have without pulling the timing cover ?
If you have DOD, you have a 58x reluctor wheel. The 24x computer won't operate DOD.
LPE has a list published.
https://www.lingenfelter.com/PDFdown...nformation.pdf
As said, ANY engine that is DOD WILL be 58x. Anything 24x can't support DOD.
Was the DOD working before the crank swap? IF it was a 24x, the computer would not have been capable of handling the DOD. The 58x computer is far more sophisticated than the 24x one.
2006 Saab 9-7x's had LH6 5.3L engines w/ DOD/AFM, and were 58x. The ONLY way yours could have been 24x is if someone previously put a 24x crank in it AND corresponding computer. Something was goofy about that setup if it was as stated.
I also know of a 2006 Envoy Denali with working AFM with an E40 ECM & black sensors.
I did hear that some of the 2005's got AFM hardware, but it was not activated. No personal experience with that.
Well, that's a new one on me! EVERYTHING I had seen and read indicated that DOD/AFM was only possible with the 58x wheel/computer combo. I apologize if I came off a bit know-it-all-ish.
Not at all, just trying to keep the info straight. Definitely an orphan motor, one year only. I wish they gave the 58x motor a different designation to avoid confusion.
