Yep I messed up HELP
https://ls1tech.com/forums/generatio...vvt-cam-3.html
There are several threads in the conversions section regarding this. I needed the info back when I was building my VVT engine. Looks like photobucket might have took a dump on the pictures, but there’s still useful info over there.
I ONLY use the Phaser, the VVT Motor, to Advance the Camshaft at LOWER RPM.
The Stops are for Camshaft Retard Limit, then the timing chain set is positioned.
Lance
By the way this just popped up lol
https://ls1tech.com/forums/generatio...er-spring.html
LOL I hear ya.
I was most interested in this part of the thread though.
http://www.compcams.com/instructions.../comp4-125.pdf
12585994 phaser uses 5456 limiter
12606358 phaser uses 5460 limiter
I ordered all the parts I needed cam, new phaser since I trashed the original, limiter and a bunch of other parts from TSP. I told them I needed the 5456 limiter since my original phaser was the 5994. Good thing I went back and ran across that thread again because they sent me the 6358 phaser and the 5456 limiter! Hopefully they will return it because that was before Christmas.
Now my next question is im using their vvt stage 3 truck cam and they changed the phaser mid year which phaser do I need? Or does it matter as long as the part numbers match?
Gonna try to upload some pictures for everyone. Everyone likes engine **** lol
http://www.compcams.com/Base/pdf/156...189%20core.pdf
