LS7 Rockers - Yella Terra?
#41
Running a 1.8:1 ratio rocker is harder on the lifter/pushrod side of the valvetrain in general. How hard it is on the valve/spring side ALL depends on the ramps of the lobe. I know quite a few lobes that will trash even a 1.5:1 ratio rocker.
Having said that, the valvetrain is a SYSTEM and needs to be designed as such. A valvespring spec'd for a lobe and running a 1.6, 1.6 or 1.7 is different than running a 1.8. When you're pushing the limits of the system, the Spintron is your friend.
Cole
Cole
How can a camshaft lobe trash a rocker arm?
I agree with your comments on setting up the spring for the rocker ratio. A Spintron is indeed a valuable tool for aquiring data.
#42
You obviously have mechanical knowledge and ability. But you also-Obviously-Have little to no machining experience, or you would know heat can-And DOES-Cause work hardening! It is NOT the only cause, but it IS one of them. Try machining some "Flexor M" alloy steel: It starts out cutting easily. If you even slightly cause it to reach, say 400 degrees, it can harden to over 52 Rockwell C, at which time even Carbide tooling starts throwing orange sparks!! Metal doesnt know, or care, what causes the heat. But whether it's heat generated from poor cooling, or from a machine tool, it's grain structure can, and will change. Valve springs are cooled almost entirely from oil. What happens when they don't get enough? Nothing good, for sure.....
#43
Please take the time to do a little research on alloy steel and heat effected strength and you will see that I am correct. Here's a few examples:
https://ntrs.nasa.gov/archive/nasa/c...9630001179.pdf
https://www.cartech.com/globalassets...-pdfs/4340.pdf
Heat generated from machining is not the same as externally heating a part.
Let's keep the topic to materials that are used in an engine. Flexor-M is a Chrome-Moly-Tungsten alloy that is not likely found in an engine. FYI, Inconel 718 will do the same thing (as will most nickel-based alloys) when machining.
Again, work hardening from bending, machining, etc. DO NOT occur in an internal combustion engine.
I'm done trying to educate people on why aluminum is NOT a bad choice for a rocker arm. Take what I've said as opinion and draw your own conclusions, but be sure to understand the facts first.
Cole
#44
Funniest thing about all this is If you go to a *shaft mounted rocker system* the problem is basically eliminated so why use a factory style rocker. If that's not liked go to a aftermarket head. Point A to B in a straight line...So why beat a dead horse.
#45
Technically, the stock or aftermarket trunnion rockers ARE shaft-mounted on VERY short shafts. The trunnion acts as a shaft. The advantage of the "shaft mounted rocker system" is the stability of the long continuous shaft. Which has NOTHING to do with the design of the actual rocker. The shaft systems just happen to use very good rockers.
#46
Well all that's fine and dandy...I started reading about BS heat cycles and crap. Straight forward I said this with all the BS to the side. Do what works and you don't have to complain or worry about guides. You got two choices with Ls7 heads aftermarket or......Name one *REAL shaft system* in which guides are going bad on factory heads.....I'm waiting? No hating G but facts are facts. Guy's can complain or just do it right. I already asked a few top builders and this was the answer.
I luv you G.... just want the facts out.
#47
Quick question and point have you are anyone heard John B (or anyone else with a real shaft style system) replacing guides or ask him or them yourself if I'm wrong. I never asked him myself, yet know the guys who has done the work on both heads besides the others I've talked too. He used factory Ls7's and factory Lsx heads with a Whole lot more of everything...springs, lift, etc.... than hydraulic roller 650 lift cams & springs or factory cams that kill guides with factory style rockers. Should tell you something if guy's read between the lines if using factory heads.
#49
Needforspeed66gt on:Speed Talk
Best thing I found about the subject online and Moldstar 90 guides with the above quote.
I highly recommend spending the money on a quality roller tip shaft rocker system and making sure it's set up properly for the minimum amount of sweep across the valve tip. Engine Machinist...
#50
And then you have the individuals that have changed their oil a few times them selves, and watched HotRod tv on Saturday morning that know WAY more than most, and love to argue and insult people. It’s a public forum, and everybody has an opinion. It’s kind of funny actually.
I actually didn’t log in for a couple years on here because of this reason...
I always recommend that anyone coming here with questions, always make sure that you can accept an answer backed by data, and not on opinion only.
