1.7 vs 1.8 rocker arms
Old 12-06-2017, 12:57 PM
Wild bill 4883's Avatar
Default 1.7 vs 1.8 rocker arms
I'm looking at replacing my rocker arms with roller tip, question is most roller rockers are 1.8 and I'm not yet planing a motor build so they will be used with stock cam and VVT until down the road. Any thoughts on if a 1.8 will cause VTP contact?
Old 12-06-2017, 12:59 PM
HioSSilver's Avatar
They likely won't cause contact but you may need springs to use 1.8s. You'll have to check that.
Old 12-06-2017, 05:07 PM
Received 3,022 Likes on 2,353 Posts
Whose roller tip rockers do you plan to use? TSP has 1.7 roller tip rockers.
Old 12-06-2017, 06:38 PM
I think I have a set of those on back order with jegs but it's been a month and no ETA. Looking for another set or if 1.8s work on a stock Vvt setup could be beneficial if and when I do build the motor
Old 12-06-2017, 09:10 PM
Call TSP and see what they have to say about it.
Old 12-07-2017, 03:18 PM
KW Baraka's Avatar
Originally Posted by Wild bill 4883
.....Any thoughts on if a 1.8 will cause VTP contact?
With the stock cam you'll be fine.......nowhere near having valve-to-piston clearance issues.
KW
Old 12-07-2017, 04:49 PM
Patron's Avatar
Comp Cams pro magnum rocker arms come in 1.7 or 1.8 your choice
Quick Reply: 1.7 vs 1.8 rocker arms
