58X Reluctor Wheel to 24X - How to
No I didn't want to buy the Lingenfelter conversion box for $274.95 or the overpriced patented tool for $209.99. I have FAR better things to spend my money on. Besides, the proper 24X wheel cost me all of $21.84 including tax.
Here's how I did it WITHOUT the overpriced "patented" tool.
1) Place new reluctor wheel over the existing wheel on the crankshaft
2) Align the 8mm hole and "triangle/oval" holes on both wheels
3) Once aligned, install a small C-Clamp or 8mm bolt/nut to hold them together
4) Mark/Scribe TWO alignment marks from crankshaft to reluctor wheel (I made them 180° apart just to be safe)
(two marks are for double verification when aligning the new wheel)
(be sure to scribe the crank starting from inside the existing wheel and outward onto the new wheel)
5) Remove C-Clamp or bolt/nut and new wheel
6) Using a hammer and driver, remove existing wheel
7) Place new wheel in oven at 350°F for 20 minutes
8) Using an OVEN MIT, remove new wheel from oven and place onto crankshaft
9) Using OVEN MIT, rotate new wheel and align with reference marks
10) Make sure wheel is started "straight" when placing onto crankshaft
10) Once aligned to the reference marks and going on "straight", use hammer and driver to tap new wheel into place
12) ONLY tap around inner diameter area of the new reluctor wheel and be sure not to bend/damage the new wheel
13) Tap until new wheel is FULLY seated against the register on crankshaft
(you'll hear a "ringing" noise when it's fully seated vs. the "dull" noise when driving it down
14) Allow reluctor wheel and crankshaft to cool until it reaches room temperature
15) Optional: Spot weld reluctor wheel to crankshaft to prevent it from slipping in the future
16) Install crankshaft into engine
17) Required: Pat yourself on the back for saving $209.99 + shipping.
How many times have you heard of the reluctor wheel shifting and causing an engine to not run?
If an engine experiences a catastrophic failure, I'd probably consider having it inspected with an alignment tool/fixture.
In the end, if you install the wheel at a slightly different angle, it won't make the engine run any different, but the timing "number" will change. For example, 24° timing before the swap may not be the same as 24° timing after the swap.
For me, it won't really matter since I have to re-tune my car anyhow with all the changes that were made.
Cole
Previously I had checked the interference fit of a new wheel and a LY6 crank I have. Cold showed .003 interference. Fine for cold pressing parts, but when heating is used it would be nice to have much more. Heating the new wheel to 400 expanded the ID .008" from the cold measurement. Hope this adds something.
The above trick works for going from 24x to 58x and vice versa. The alignment holes in BOTH wheels are the same.
Cole
I will report back once my engine is back in my car and we begin tuning (HP Tuners). This will be my first chance at learning tuning. Another well experienced person is doing the tuning for me and I will learn from him. I can ask him these questions once we get into it all.
As far as your crank WITHOUT a wheel on it, then I would suggest using an alignment fixture for that install. The alignment of the wheel to crankshaft is determined by the non-threaded hole in the end of the crankshaft and 8mm hole in the wheel. According to my GM models, the angle between the two should be 123.05°. I went to the trouble of creating a 3D model and drawing to make my own fixture. In the end, I didn't need to do this.
Thanks,
Cole
Thanks,
Cole
I do want to check the location of the wheel on my LS7 also. It does run fine with the exception of a random misfire code accompanied by a rich condition at idle and very low speed/low load driving (it’s not a real misfire though). It’s a strange problem and I don’t want to clutter this thread with it unless it turns out to be relevant. I’ll report back with results.
Cole
