Viper Pushrods in LS3?
Long story short, I want to fit a double tapered 3/8" pushrod and it needs to be at least 7.600" long. The straight 3/8" binds and clearancing the pushrod holes is not really an option for me.
If they aren't compatible, is there a company that makes a set at a good price? I can get a set of 20 from a reputable brand for $344.
Thanks for any help!
Believe it or not, I took the heads off to get the holes clearanced. The machine shop tried to drill a hole all the way through and cut into the intake runners in the process (these are AFR heads). Long story short, there are now sleeves pressed into the holes and I'm worried about drilling into those.
I don't think I necessarily need 3/8", but I've already nearing $2k invested into the valvetrain so might as well get a good set of pushrods too. 11/32" were next on my list for test fitting if these Viper ones won't work out.
What put me on this path was the writeup by vettenuts on the CorvetteForum. We're both using AFR heads with the same pushrod brand.
https://www.corvetteforum.com/forums...stiffness.html
@KCS I was looking at them earlier today! Unfortunately the length skips right over the range my adjustable rockers can compensate.
