Gen IV Connecting Rods
Gen4 rods will of course work with floating pin pistons BUT you cannot use press pin style (gen3) pistons with a gen4 floating pin rod.
Gen4 rods really werent "gen4" its just an easy way to label them. They started in 04 for the lq9 and a few others but every 05+ engine and every gm reman from around 2009 and up used them.
If that is how your engine came, then it never ran. The pins would hit the cyl wall on warmup.
they are in fact just exactly what OP states. beefier Gen 4 type rods with a bushed small end and a pin that is press fit into the piston.
both sets came from 24x tooth truck motors
the one in my NA truck has been a beast. a year of 18 psi on pump gas, no meth and now it pulls down 18mpg on the highway hauling yard debris haha
I did disassemble one and it had the normal gen4 type bronze small end bushing with a chevron shaped oiling groove.
