Oil Pump Question
When we tore the motor down, discovered the #2 and #4 main bearings were worn pretty good (possibly from poor crankshaft balance from ERL and ) and thinking that caused the oil pressure issues.
Building a new motor now and wondering if I would be better off using a Melling 10355 or 10296 over the Schumann’s pump. The oil system has at least 6’ of external -10 lines to a remote oil filter mount and external cooler and the new motor will see 8000+ rpm.
I have seen those who save money by adding weights to the Flywheel ?
Could you post pictures of #2 & #4 ?
Lance
You would be better off with the 10296 in my opinion.
What pan are you running and what filter?
On the 10296 i would def port the inlet and short turn/outlet to make transitions easier and have less issues with temp building prematurely. ALSO add in the saccity billet oil barbell for added security. Does your remote mount have a bypass built into it also?
The pan is a Moroso and filter is a Wix 51060R
Remember they get oil last so if it were an issue that they would be pretty trashed.
Youve gotta be careful with such high pressure you can blow the valley cover o rings if its a gen4 block. I would actually either tap and plug them or use the lingenfelter style rivets to keep any oil from short circuiting its path.
Im a fan of that anyway actually. Seen it fix a few erratic oil issues on afm deleted trucks.
I knew you were talking about porting the pump. I’ll probably stay with the Schumann’s pump.
I mentioned this in another thread but during a 1/4mile pass I shifted from the top of third gear to second and rpm went to 8400. I later discovered the pilot bearing had come apart and I think that is what caused the crank flex and took out the bearings.
Already had tapped the DOD towers and plugged them and will be doing new block also.
Tim
Your RPM MAX = 7800 - 8400 ?
The Amount of Oil Held by the Piston Bottom (under crown) and Crankshaft/Rods could require an "Over Balance" of 2% as common ?
I also ask how your Two Step operates ?
The bearing pictures are great, with my observation as unseen in my past.
The "local guy" tech could be reported ?
Lance
Lance
RPM max, two step was set to 8k. It went to 8400 when I shifted from the top of 3rd gear to 2nd gear...Mechanical over-rev.
Holley EFI two step is set to “high only” 8000rpm
Can you explain the last two statements please?
“The bearing pictures are great, with my observation as unseen in my past.”
“The "local guy" tech could be reported ?”
Oh, the oil pan is a Moroso 21150.
Last night I noticed the oil pressure on my truck (factory gauge) is at 45 cold idle and then drops to 40 when it warms up and around 50+ cruising and it has 120k miles.
Most of my engine inspections see Main Bearings as in NEW Condition.
YOUR "local guy" reported to you "the balance was way off."
My question related to his report ?
The Holley Rev Limiter Method is my observation of a possible cause of Bearing Damage.
My ECU retards timing first as a Soft Touch for Start Line with smooth engine operation.
Did your 8K limit sound even ?
1839 Bob Weight = "0" Balance
Lance
