cam sensor damage
Old Jan 31, 2018 | 07:18 PM
k1500coburn's Avatar
Default cam sensor damage
Anyone ever had an LS2 cam come in contact with the cam sensor? 170,000 miles. wondering if anyone else had to go in a change the thrust plate and what else could be wrong before i dig too far into it.
Old Jan 31, 2018 | 10:32 PM
Unless the sprocket came loose from the cam (very possible), the thrust plate would be it.
Old Feb 1, 2018 | 07:14 AM
I will take it apart this weekend. I'll post pics of the carnage. The engine has never been apart as far as i can tell. I've only owned it since September.
Old Feb 1, 2018 | 07:28 AM
dreadpirateroberts's Avatar
Possible the cam retainer plate bolts started coming loose, but you would lose oil pressure.
Cam gear bolts could also be backing out.
Old Feb 1, 2018 | 12:59 PM
ColeGTO's Avatar
I've been told that for some reason cam bolts like to back out of LS engines. Don't know if it's really that common.
I used red Loctite, drilled the bolt heads and safety wired them in place on the engine I just finished. Can never be too cautious with fasteners.
Old Feb 3, 2018 | 09:59 PM
Thumbs up
ColeGTO called it. loose cam gear. after 176,000 miles, i'm not sure why now.
8 hours to get it apart. now to order parts, clean and reassemble.
Old Feb 3, 2018 | 10:09 PM
Use Loctite on the cam bolts, but maybe you knew that...
Old Feb 3, 2018 | 11:19 PM
brandon6.0's Avatar
Hmmm never seen a cam sprocket come loose. Use some blue loctite
