cam sensor wiring
Old Feb 2, 2018 | 02:49 AM
xrtim's Avatar
Default cam sensor wiring
I'm looking for so help on wiring up the Gen 1V cam sensor to a megasquirt MS3 Ultimate, I understand that the sensor needs a 5v supply which i can connect to one of the VREF 5V + outputs from the ECU and then connect the CMK + and a sensor return. The problem I have is with the connector pin designation, I can't seem to find any information on the connector I have, looking into the 3 pin pigtail connector with the locking tab up I have right to left A terminal red wire, B in the middle pink and black wire and C brown and white wire. Can you tell me which wire goes to where, or in idiot speak how I can test sensor to find out.
I'm thinking
A terminal red wire 5V+ in
B terminal pink and black sensor return -
C terminal brown and white ECU to sensor +
Never done this before so bear with me and the engine hasn't been run before just finished building it.
Regards Tim
Old Feb 2, 2018 | 06:16 AM
LS1MCSS's Avatar
Pin C, 5V reference.
Pin B, Low reference
Pin A, Crank sensor signal.
Just an FYI, I found this on LT1Swap.com
Old Feb 2, 2018 | 08:15 AM
xrtim's Avatar
Thanks for the information, will wire that up tonight and move on to the next one
