The Pontiacolypse
Old Apr 7, 2018 | 11:39 AM
  #181
sxc Z28's Avatar
Nice build Darth! Will be interested to see your response on the coils upgrade assuming that's the only thing changed and the before/after. Don't forget the computer will need to relearn the coils so it will hunt/surge until it finds idle. Mine did it for about 20-30 seconds.
Old Apr 7, 2018 | 11:47 AM
  #182
Darth_V8r's Avatar
Moderator
Thanks for the heads up, SXC!!
Lance, I'm really excited - and actually a bit scared - what the ITB will do. Its already insane. And I'm looking at the controller being maxed out too, so this will be fun.
Old Apr 17, 2018 | 04:47 PM
  #183
Darth_V8r's Avatar
Moderator
Right now, I wouldn't change a thing on the cam. It drives pretty good, revs great, makes great power. I can't really take credit for the cam. I had an idea where I wanted it to be, but Phteven at Cam motion recommended differently vs my thoughts, and I went with his instead. I'm very happy with it. If, and I mean IF I decided to change anything, I think with ITB it could tolerate more overlap. But I like the IVC and EVO where they are. Seems like a great match for the displacement and compression I'm running.
I got to looking even more at this...
If I was really interested in a bigger cam, like if I thought I had a shot at crossing a threshold (700 RWHP or 9.5s 1/4 ET for examples) I would do something like 252/266-111+2, which after accounting for solid lash, would "shrink" to 246/260-111+2 with 31 degrees overlap. I think this would raise the torque curve, shift it to the right a bit, and carry further past peak power.
But let's be real... I can't plant power now. I broke the car loose at 100 in third gear when I hit peak power, which was scary. The nice thing is this thing tracks straight when the wheels spin, so I didn't go sideways. Then, in an attempt to load up and just get airflow numbers, I took 4th to the top, and at 6400 rpm and 125-ish MPH, started getting wheel spin. So, a bigger cam isn't going to help me do much of anything. I do think that the ITB WOULD make a cam that big drive quite nicely, though, so I'm still very intrigued by the possibilities
Old Apr 17, 2018 | 06:13 PM
  #184
spanks13's Avatar
What tire do you have on this thing lmao
Old Apr 17, 2018 | 06:34 PM
  #185
Darth_V8r's Avatar
Moderator
Right now it's 28x10.5 radials. Gonna step up to QTP. I ran QTP last time at the track. I'll just put them in and see if they do any better
Old Apr 17, 2018 | 09:01 PM
  #186
spanks13's Avatar
I’ve heard and seen good results with the QTP. I’ll be using them on a 16” wheel next time I want a drag tire on my car. I tried Mickey ET Street S/S and did not like them at all. I’m a Hoosier guy through and through on our race cars.
I’ve had really good luck with 255/40/17 R888’s on the street. That was with 450rwtq, 4.10’s and a short ratio MN12 T56 in a 2850 pound rx7 with IRS and road race style suspension.
Old Apr 17, 2018 | 09:14 PM
  #187
blk00ss's Avatar
What type or radials? No way you should be breaking loose in third or fourth lol. I’m betting that you need a new set is all. That or your suspension is really out of wack.
Old Apr 17, 2018 | 09:18 PM
  #188
Darth_V8r's Avatar
Moderator
Yeah the tires are old. They're mickeys. I just did not want to put Hoosiers on for daily use.
Old Apr 17, 2018 | 09:25 PM
  #189
blk00ss's Avatar
Get a new set of mickeys. 325/50 et street r.
Old Apr 17, 2018 | 11:49 PM
  #190
NSFW's Avatar
Ideally it should be. I'm losing 6 kpa at WOT. Hence over scavenged
I see - I misread what you were saying earlier.
How much of that 6kpa do you think you can blame on the air filter? Is there one? What model?
Old Apr 17, 2018 | 11:53 PM
  #191
Darth_V8r's Avatar
Moderator
I'm running the volant filters, which sustained 97+ kpa on the old motor. Granted it's flowing 100 g/s more....
Old Apr 24, 2018 | 02:59 PM
  #192
spanks13's Avatar
This should be fun. I've got an LS7 short and scooped up the BES 282cc heads that were on the classifieds today. It'll take me a while, but we'll be able to compare 428's. You'll probably have the ITB's going by the time I finish my lump. I've got another $5-6000 to go to get this thing running. Gross.
I was looking at the Brodix BR7 heads, but after spec'ing the valvetrain appropriately they were way too expensive. I don't need the strength or the extra bolt locations.
I might steal your Pontiac nod. My swapped rx7 was nicknamed the "mazgoat" by my friend because the original LS2 came from an '06 GTO. I guess the name will still fit
Old Apr 24, 2018 | 03:01 PM
  #193
Darth_V8r's Avatar
Moderator
Pontiacs are the coolest chevy's!
Old Apr 24, 2018 | 04:13 PM
  #194
Might just be the coolest quote I’ve ever read!
Old Apr 24, 2018 | 04:26 PM
  #195
I like it! The Poncho guys are gonna LOOOOVE it! lol
Old Apr 24, 2018 | 07:27 PM
  #196
joecar's Avatar
ha lol
Old Apr 26, 2018 | 11:17 PM
  #197
JakeFusion's Avatar
Super Hulk Smash
I re-read and realized I didn't answer most of your questions.
The over scavenging will just get worse from 6500 up to 8000. The MAP will just steadily fall. It is not unexpected. It's a stock LS7 intake. I knew it would be a limitation on the build, but they're so cheap and plentiful in the wild, it made it easy to just get the car running.
I've been paying attention to hammer's threads, and I'm guessing the stock controller will struggle to keep up at some point. M y intent is to go with Lance's controller when I do the ITB. I'll still need the stock ECU to monitor the car so it can smog out.
Hope all that helps...
I wonder how that cam would do with a MSD on the LS7? Since I'm cheap. lol
Old Apr 27, 2018 | 10:10 AM
  #198
pantera_efi's Avatar
Default FL Emission regs ?
Hi Jake, I have a "Condo" (P.O. Box) in a county of CA> wherein there is NO Smog test required for yearly reg.
I do not know the Emission Laws in FL.
Would there ALSO be a location (county) in FL with NO smog testing required ?
I have a "single" 65mm ITB casting. (eight required)
These could be assembled as a "cross ram" with head intake plates ?
Lance
Old Apr 27, 2018 | 05:25 PM
  #199
JakeFusion's Avatar
Super Hulk Smash
Zero emissions laws in Florida.
Old Apr 30, 2018 | 05:57 PM
  #200
Darth_V8r's Avatar
Moderator
Minor update, but after doing some suspension tweaks, I've been able to get third gear to hook. Had a couple really fun pulls this morning -- the car, you perverts!!
Was behind a semi at 40 mph in fourth, gunned it to get around him in the opposite lane, and hit 90+ by his front bumper. Rolling from third, I'd expect that, but from fourth surprised me. Got another really good run second through fourth and its shifting great, let off at 125, but it was still pulling really hard. I'm going to have to invest in more stopping power. I'm thinking the dual caliper strange rear brakes.
And one faux pax. I was passing a minivan, gear-clashed going into third and when I was right next to them, the motor just free-revved at full throttle. I felt bad, and I'm sure it scared the **** out of them.
