So I blew my brand new LS3 crate engine
Blew my LS3 525 crate motor from Chevy. I’m never gonna buy another GM crate motor knowing what I know now.. but check out these pictures because I thought I spun a bearing and that lead to oil starvation.. but when I took it apart I saw this.. how does this happen on a motor that’s 3 months old and ran at normal op temp.
indeed it is. i had high temps on the track and i found out that my air dam was blocking the oil cooler just enough. i had low pressure @ idle only and once on the throttle i had fine pressure. i did replace the pump and it ran great and had zero issues till this. when it blew thats exactly what i thought, i threw a rod because of oil starvation. but when i opened it up i found this. if the rod came apart from the piston and went into the wall i would think it would be a more direct center hit as to the rod can only go in the direction. this hole is off to the side a bit. also i would think if the rod went into the wall it would not be so high or in an area where the piston skirt would be. im kinda dumbfounded by this.
Something gouged the wall several multiple times and knocked a hole in the sleeve, I can't see a soft aluminum piston doing that so it's either the rod or the pin, My guess it was probably the pin.
Edit: Looking again at the gouges in the first picture it definitely was the wrist pin that did the damage to the cylinder wall, As far as why the piston broke in the first place I have no idea. Probably not much of it left to do a good analysis.
gonna try and warranty claim this. see what happens.. regardless i bought a dart 427 so this never happens again.
Saw this coming from your last thread
Your engine was damaged before from the high oil temps then you wrongly put a high volume pump in without having any more volume of oil Your low idle pressure was a sign. The engine was begging you to tear it down and fix it Now you have an expensive coffee table and are mad at GM. Your next engine will expire in a similar fashion unless you run a dry sump system and there’s even a pan mod for that to help scavenging for Auto cross type applications
Do your homework and listen to the experience of others
The oil temp and follow up pressure issues wear the Babbitt off the shells. When the clearances become huge the piston is now traveling farther “north” eventually hitting the head. Hyper pistons are strong but brittle. This is when the pin pulls out the bottom and smashes the cylinder walls. You have yet to remove the rod Big end which will show you what happened here.
The high temp issue came from an track day of running multiple laps at WOT. And like I said I found out that my front air spoiler was covering my oil cooler just enough to not direct proper airflow. My focus RS runs that high oil temp wise on the same track. It did have low oil pressure but it was still within the factory specs according to the manual that came with the engine.
Here’s the thing.....rods don’t throw. Pistons rarely fall to pieces
As far as oil pressure is concerned, GM's minimum pressure is also at a minimum oil viscosity, I imagine at 280* it was as thin as water.
I've never seen it marketed as a "competition" motor, just as a regular LS3 with an ASA cam in it. NO more, no less. If you're gonna race, at least you should make sure the engine is up to it. You had a production LS3 with a cam swap done by GM.
Exactly, and I feel like it wasn’t.
