Ls3 NA Build For My Focus
Old Mar 12, 2018 | 09:45 AM
Puck's Avatar
Originally Posted by topspeed1
That is the engine.
How much spring pressure do you think i need?
I think we might be making progress...
Those springs included with the 255 TFS heads are pretty modest, at 400# open. These are the specs:
Code:
Valve springs: Standard
1.300" O.D. dual spring (TFS-16904-16)
150lbs. @ 1.800" installed height
400lbs. @ 1.200" open
370lbs. per inch rate
1.075” coil bind, .625" maximum lift(OE style rocker arms)
The spring Comp recommends for that cam is the 80540, which is 155# on the seat and 420# open - slightly higher, but that is at 7000rpm. If you are spinning 7500-8k, you would need even more. As for the exact spring pressure or part number to run, I have no idea and wouldn't be qualified to make that suggestion. I would get with a pro that spec's cams for the LS3 and ask their opinion.
You are not only on the ragged end of max lift (.624 lift on that cam vs .625 max on those springs), but also under recommended spring pressure for that cam at 7k RPM - let alone 7500+. The upgraded option spring for those heads would be a good place to start, PN: TFS-16306-16.
Code:
Option 1
1.300" O.D. dual spring (TFS-16306-16)
155lbs. @ 1.820" installed height
465lbs. @ 1.200" open
463lbs. per inch rate
1.100” coil bind, .650" maximum lift (roller rockers)
Old Mar 12, 2018 | 10:06 AM
topspeed1's Avatar
Code:
Code:
Option 1
What do you think about installing a bigger rocker while im changing the srpings? a 1.8'1 should get me .660ish lift and the heads flow well to .700 lift.
Old Mar 12, 2018 | 10:41 AM
Puck's Avatar
If it were me, I would bite the bullet and spend the coin on a nice 1.8 shaftmount setup, which will handle the ~7500-8k RPM you will need no problem, and then have a qualified pro spec the proper spring for that cam with a 1.8 rocker since it will not only be higher lift than what it was specced for, but higher rocker ratio also makes the lobe act more aggressive requiring increased spring control. Those lobes already get off the seat pretty quickly, and a 1.8 will make that even more aggressive.
Just caught that you did the trunion upgrade on your stock rockers, which should take care of the biggest issue with them. Honestly it would make financial sense to just install the proper springs and keep everything else the same for now. See how it does, then if you are still not happy you can step up to the 1.8 setup. You will likely see ~575rwhp with the proper springs, and even though it wont be your goal it will save you probably $1200+ vs the shaftmount setup...although even though your HR isn't dealing with crazy high spring pressures, at 7500+ RPM the shaftmounts are still FAR superior to a stud mount rocker.
Old Mar 12, 2018 | 11:17 AM
spanks13's Avatar
Contact Johnson and get their recommendation for max spring pressure on their lifter. Too much spring and you'll pump down the lifter even with the short travels.
Hydraulic roller is fine for a drag car. .625 lift is also plenty. A solid roller will definitely run better and allow you to run more lift, but for an extra $3000 I'm not sure you really need it.
Dustin Lee regularly takes his hydraulic roller LS engines over 8000 rpm with stock rockers and .625 lift.
For what it's worth, I think your valve events are all wrong. Is your intake manifold a short runner tunnel ram style? I think you need tighter centers and a much earlier IVC, even for high rpm.
Our stock bottom end LS3 with a Victor Jr intake and ported stock heads HP peaked from 7100-7400 rpm with a comp 239/251 on 110 installed at 108 with the Cadillac road race ceramic lifters and stock rockers. It made 528rwhp through a 6000 stall converter and a powerglide and 9" slicks.
I think something like 243/255 on 108+2 would work a lot better for you.
Old Mar 12, 2018 | 12:43 PM
topspeed1's Avatar
I think Im gonna start by replacing the springs and see where that leaves me.
Old Mar 12, 2018 | 07:06 PM
At what rpm did you experience tire spin, to have to roll in slowly?
I don’t see tire spin on your graph.
Old Mar 12, 2018 | 08:06 PM
topspeed1's Avatar
That chart doesnt reflect the wheel spin because of how slow i rolled into it. But there were others where it is very apparent
Old Mar 12, 2018 | 08:35 PM
KW Baraka's Avatar
That is the engine.
At a minimum: --->> http://www.pacracing.com/RPM-Series-...1207X/Item/763
KW
Old Mar 13, 2018 | 06:37 AM
Ill ask again...at what rpm were you spinning on the dyno?
Old Mar 13, 2018 | 11:01 AM
topspeed1's Avatar
Pretty much whenever i punched it. 4500rpms or so
Old Mar 13, 2018 | 08:14 PM
I don’t understand this. At 4500, your making 210 hp. No way your spinning...even with a 175/70/15, 20 year old tire.
Post up a chart that was a full throttle pull.
Old Mar 13, 2018 | 09:09 PM
  #32
topspeed1's Avatar
At partial throttle at 4500 rpms its making 210 hp or whatever but as soon as you floor it it makes way more than that and the tires spin. At that point it is probably making 450+ lbft which is what spins the tires. If i gradually roll into the throttle the tires dont spin.
Old Mar 13, 2018 | 09:23 PM
  #33
spanks13's Avatar
Also if the torque converter is worth a damn it’s multiplyig torque by 1.5+ times when it flashes..
Old Mar 13, 2018 | 09:27 PM
  #34
Lol. You never made 450 ft lbs. Ever.
And if you could make 450 ft. Lbs. that’s not enough torque to spin the tires on a dyno. Lots of guys make way more power than this, and don’t spin on the dyno.
I’m not trying to bust your *****, I’m simply trying to see into what’s going on here. Lots of questions asked to you in this thread that you didn’t answer.
Old Mar 14, 2018 | 01:31 AM
  #35
KW Baraka's Avatar
......At that point it is probably making 450+ lbft which is what spins the tires.......
Huh?
KW
Old Mar 14, 2018 | 01:33 AM
  #36
KW Baraka's Avatar
Lol. You never made 450 ft lbs. Ever......
Yep.....that's what I saw, too.
KW
Old Mar 14, 2018 | 03:16 AM
  #37
Vdop's Avatar
Reading comprehension is not a strong suit for some of you. Why are you guys so hung up on the torque? The guy has repeatedly explained that it was not at wot and you can clearly see that it was not getting it til at least 6k or higher. He also explained that torque is not a concern and he wants it to make more hp and carry further. Do you guys honestly think this 376 is making 100ft lbs @ 3000 and 250ft lbs @ 4500 just because the cam is a little bigger than you're used to?? You'd probably have to pull 6 plug wires to accomplish that.. or not be on the throttle all the way! Puck made some great observations and seems to be headed in the right direction.
Bottom line is, op has a bad little bitch with more on the table. A 376 with a shelf hr making 550 to the tire through a high stall auto is no joke. Better hope you don't end up next to this thing with your big stroker
Old Mar 14, 2018 | 06:43 AM
  #38
Your right, and I’m totally wrong.
Still waiting on full throttle dyno chart....lol.
Old Mar 14, 2018 | 06:57 AM
  #39
Vdop's Avatar
There's a wot dyno sheet in the first post. It's wot in the rpm range that the op built the engine for and wants to improve. Got anything constructive to help him out?
Old Mar 14, 2018 | 07:05 AM
  #40
Jmf0620's Avatar
I had to make an account just respond to this. Your level of ignorance on running a high stall converter on the dyno is astounding.
Even if he gets a WOT pull from 2k rpms the chart won't register until after the converter flash hooks up, so likely after 5k by the looks of it. This doesn't mean the engine doesn't make torque lower than that, only that because of the torque converter, you can't sample it on the dyno like you can with a manual transmission car. It would be like slipping the clutch until 5k.
