Broken Valve Guide LS3 Trick Flow 255s
They are brand new trick flow 255's only and few dyno pulls on them. What now? What could have caused this? Defective? Cracked when the heads were put together?
Input please.
As to how it happened, that looks like a powdered metal guide, and it likely had a non metallic inclusion for it to fail like that. Without seeing it in person or looking under a microscope, that is.
Edit - are you missing some aluminum near the base of the valve guide also?
The piston looks ok and you might get a free head. Might be a bad batch of guides or a one off with a fracture. I wonder if they x ray the guides before installation?
I can supply our Steel Guide ?
MY GUESS is another FOUND CASE of a cost reduction COSTING END USER BIG MONEY (-.50 cents savings each guide)
Lance
I have to say, I'm very tempted to run these with the titanium valves in mine. When I upgrade the heads, Ill be in touch.
Bronze also has certain inherent lubricating qualities. The downside is that it is soft, so any sort of sideloading is going to exacerbate guide wear. This is why a roller tip rocker is heavily suggested for any head with bronze guides.
Here is a copy of their warranty
Trick Flow Specialties guarantees original, unmodified cylinder head castings against manufacturing defects. Trick Flow Specialties’ liability is limited to replacing the casting.
The valves, valve guides, valve seats, valve job, valve springs, valve spring retainers, valve locks, rocker arm studs, guide plates, and valve stem seals included on assembled Trick Flow Specialties cylinder heads are warranted to the original purchaser to be free from defects in materials and workmanship for a period of two years from the date of purchase.
This warranty does not cover:
• Failure due to improper installation or maintenance, abuse, misuse, unauthorized repairs, modifications, or alterations determined at the sole discretion of Trick Flow Specialties. If your machine shop, engine builder, or installer performs any unauthorized repairs, the warranty is voided and Trick Flow Specialties will not reimburse any cost you incurred.
• Removal or replacement costs.
• Costs incurred due to down time of the vehicle.
• Damage to related components.
• Marine salt water corrosion.
• Corrosion from not using and/or refreshing antifreeze.
• Fitness for purpose or merchantability.
All other Trick Flow Specialties products are warranted to be free from defects in materials and workmanship for a period of 90 days. There are no mileage limitations.
I bought them on January 15, 2018 which was 60 days ago
