Piston pin question
Old Apr 5, 2018 | 07:21 AM
dmracing's Avatar
Default Piston pin question
I have genIV rods from s 5.3. I want to use the rods in a 6.0. I have new LS2 pistons, but no pins. Can I reuse the pins from the 5.3 pistons for the 6.0 pistons
Old Apr 5, 2018 | 10:27 AM
pantera_efi's Avatar
Default Engine Balance Weights
Hi Dm, the "better" answer should be based on the weights/costs.
Will you balance the engine ?
The chance the install a "heavy" rod could be MATCHED to a Light Pin with NO net change in BW.
Lance
