Double roller timing chain fitment on a LC9 5.3 liter
Anybody out there know if the comp cams double roller timing chain set will work with out any modifications to the oil pump or timing chain cover? The 2 Comp Cams kits I was looking at was was either the 7106 or 7102 part numbers. This will be going on a 2011 sierra, 5.3 liter that is gonna be around 500 horsepower. Any help will be appreciated!!! Thanks
I don't know how dead set you are in using the double roller chain, but the LS2 single roller will easily get the job done for what you want. Usually you have to space the oil pump from the block for a double roller chain.
Hi CB, I can supply the strongest SINGLE billet timing set, STRONGER than the Dual Chain.
NO spacers, grinding, worries with this Billet Steel Avon set at a cost of $158.00 USD.
This Timing Chain has Oil Holes, good for long chain
life.
