Built ls3 with mods, low torque numbers
I bet he has an LQ4 or LQ9 block being it's cast iron, which I caught from the first post.
Also seen from the first post, he says it has only top end power, which indicates to me a retarded cam.
I remember my '78 Ford E-250 van with 460 had the factory retarded cam and it couldn't get out of its own way. It ran out of breath before the cam had anything to say...
The red headers can only be two things...retarded timing, or a lean fuel condition. Your ignition timing sounds good (assuming it’s correct), maybe a tad much, as said earlier.
Do you know what your AFR readings were?
Ok, you’ve gotten good advice a couple times already, but I’ll say it again...you need to put a degree wheel on the crankshaft, and check the cam timing. Make sure your camshaft was ground correctly before you change anything.
Sounds to me like you need fuel, and fuel equals power, but I don’t understand the “average” term you used. Would definately explain the red headers however.
I give up.
Red headers tends to be low idle spark, like under 15 degrees. LS likes 18+ degrees at idle. Other cause is lean condition at idle or both. This can fool you because some cams like to idle lean. But it is actually false lean due to overlap. Keep running it, eventually your oxygen sensor will overheat, ignite, burn up your harness, and your low torque issue will be long forgotten. Or solved. Depending on your point of view. I doubt only one primary is glowing. More likely the wrap is hiding it. Take the wrap off I bet your headers are a really cool looking purple.
You do not need expensive pistons to gain compression. Just mill the heads and go to a thinner HG. But honestly, I think your cam is just too big. If you post a tune file we can look. I will reserve judgement until then.
