Built ls3 with mods, low torque numbers
we built ls engine for my friend’s drift car.
Engine is 6.2 liter, cylinder block is cast iron, bored to 4.030, wiseco domed pistons, stock crankshaft. Cylinder heads are LS3, cnc ported, camshaft is 281lrr-hr13, holey short ram ebay replica manifold, 102mm throttle body, headers. Compression ratio is 10.5:1. Engine management is Link G4+ Storm ecu.
After dyno tuning we got 433whp and 407wtq. These numbers are pretty low compared to previuos engine I built, it was 6 liter with lq4 cylinder heads.
Engine has only top end power, the headers becoming glowing after few runs on dyno or track, I’m suspecting that cam timing is wrong, what do you think?
Regards
Anyway.....Goga, did you dyno the car before the cam swap? Knowing where you were versus where you are NOW would tell you a lot more than simply looking at the current peak numbers.
Also.....that 10.5:1 compression ratio is low for a cam with that much duration. Ideally, I'd want to be around 11.2 to 11.5:1 with that cam.
KW
You said that intake is a replica holley. I would take a close look at it for starters. Those intakes are for top end power. But at that power you have no power in general for what it is. Should easily go over 500whp if it's right.
KW
dyno chart
Also, the cam you have needs more static compression to be at its best.
By the way, what about headers becoming glowing red?
check the header pic at cylinder 5 spark plug wire
