Springs for BTR Stg 2
I'm thinking about the nascar used PSI 1511ML. Thoughts?
I have some scorpion rockers that I was thinking of using. Should I run them or do a trunnion upgrade on stock rockers instead?
Thanks
https://www.racingsprings.com/index..../category/403/
And I would also go with a trunnion upgrade on the stock rockers over the scorpions.
KW
Thanks
I vote for bushing trunion upgrades on the stock rockers, don't do the bearing style, there's too many people having issues with them wearing out quickly.
Not sure when you got your scorpions but a while back there was a rash of them breaking.
I would call BTR and ask them the best spring kit for THEIR cam.
As for the rockers, theyare almost brand new, just dyno time on them, and look perfect. I thought there wasan issue with running stock rockers at >.600 lift? Does the trunnion kit change this? I assumed it was a scrubbing/side loading thing due to geometry.
You'll be fine with your stock rockers, the trunion upgrade is just to keep from having the stock bearing trunions take a dump inside the motor. It keeps the same geometry.
You could also ask BTR, they will likely recommend the stockers over the scorpions.
