What is "stress relief" on an engine block?
Old Oct 2, 2018 | 08:58 PM
FCar2000TA's Avatar
Veteran: Air Force
Default What is "stress relief" on an engine block?
I frequently look at websites that do Darton Sleeved LS blocks and dream (my wife says it's car ****), and I noticed that R.E.D. talks about stress reliving their blocks when they install sleeves. What is that? Is this like cryogenic treatment on transmission gears to eliminate weak spots?
Old Oct 2, 2018 | 09:12 PM
It's a form of heat treating to "relax" the metal from stresses caused by localized heating and cooling caused by machining operations.
Old Oct 2, 2018 | 09:17 PM
I could be wrong...wouldn’t be the first time...but I think that Steve told me he uses vibratory stress relief, meaning the block is fastened to a vibrating table for a certain period of time, before sleeves are installed.
Old Oct 2, 2018 | 09:18 PM
Sounds like a Jack LaLanne method....
Old Oct 2, 2018 | 09:19 PM
LLLosingit's Avatar
The stress relieving I'm familiar with involves smoothing or removing casting lines/sharp edges and generally cleaning up poor casting features like oil return holes.
The idea is to stop cracks before they get started and to remove material that could end up damaging the engine if it comes loose down the road and improve oil flow to the oil pan.
Old Oct 2, 2018 | 09:45 PM
99 Black Bird T/A's Avatar
That's my understanding as well plus ideally vibration table.
Old Oct 2, 2018 | 10:17 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
You are right, stress relieve can be vibratory shaking, cryogenic treatment, and removing flash and
stress risers/ smoothing with a dremel. Vibration/Shaking and cryo affect the metal on a molecular level
designed to provide a harder and more thermally stable Block and Bore. Block prep by
removing casting flash and irregularities to prevent flash coming loose in the Oiling system
etc, and to prevent cracks from "stress risers.
Old Oct 2, 2018 | 10:43 PM
Bazman's Avatar
Vibrators, **** and stress relief is all enough to make a man think
Old Oct 3, 2018 | 04:43 AM
8.Lug's Avatar
That's a way to prevent cracks from forming but it's not a stress relieving process.
You know how you have to heat metal when you're shaping it or else it will break? That's a type of stress-relieving. When metal is shaped or when it solidifies after being cast, stresses build up inside it. These stresses can cause fractures. So, there are a bunch of different ways to relieve these stresses - cryogenics, heat treating, vibration, etc - but they all basically focus on the same thing - realigning the molecules in the metal. Now the metal can withstand a lot more force before it fails.
Old Oct 3, 2018 | 06:03 AM
RB04Av's Avatar
It is usually accomplished using technician attitude adjustment fluid, with the block serving as a seat.
Seriously, the most common form I know of, is shot-peening; but you'd need to contact RED to see what they actually do.
Old Oct 3, 2018 | 12:29 PM
KCS's Avatar
KCS
Moderator
I’ve visited Steve’s shop in California and I can confirm he had a vibratory table to perform the stress relief.
Old Oct 3, 2018 | 01:44 PM
ColeGTO's Avatar
In the aerospace world we use "stress relieve" for various reasons. It is most common when larger amounts of material are removed and the residual stresses are present in a lesser amount of material which will have a larger effect on dimensional conformance, stress fractures, etc. Another example is grinding, a "smearing" type of machining process and stress relieving is often used to remove the stresses that were introduced into the part as part of that process. Per the industry standard specification for thermal Stress Relief of Steel Parts - AMS-2759/11 the definition is as follows:
1.2 Application:
Stress Relief of parts is performed to reduce residual stresses and thereby improve dinensional stability, decrease warpage during machining, and facilitate subsequent forming operations. It is also performed prior to plating or other chemical processing to prevent cracking during processing.
Stress Relieve can be accomplished in many different ways. Heating is one of the most common. The material is heated to typically 50-100 degrees below the "aging or tempering" temperature so it does NOT alter the strength, or hardness.
Old Oct 3, 2018 | 03:16 PM
Darth_V8r's Avatar
Moderator
If anyone is interested.....
Metals have a crystaline atomic lattice. The easiest way to explain it is to think of a Rubik's cube. Aluminum and steel both tend to be cubic, and that's the easiest one to work with. The atoms will ultimately reach their lowest energy state when arranged in cubes. Misalignments of the atoms in the lattice cause increased hardness, but also increased brittleness. Similar to twisting one face of a rubik's cube slightly out of alignment -- it is harder to move the cube when the squares are not all properly aligned. Far enough misaligned and the cube just breaks. When they are realigned, the cube is easier to move
Whenever metals are first cast, forged, formed, rolled, etc, there are a lot of internal stresses due to random misalignment of the atoms from the freezing or forming processes. If you take a freshly made piece and let it sit long enough, eventually, the atoms will align themselves in their lowest energy state, which in steel and aluminum is cubic. This realignment is sometimes referred to as polygonization. Heating the metal, vibrating the metal, or both accelerate the aging either with thermal or kinetic energy. Heat expands the lattice, which makes it easier for the atoms to move around and reach their lowest energy state. Vibrating adds energy to the system, which helps atoms that need to slip do so more easily. Either way the result is the same. Reducing the chances of a catastrophic failure.
Old Oct 3, 2018 | 03:27 PM
ColeGTO's Avatar
Very well said. And within that group you have "face centered" and "body centered" grains depending on the material type.
Metallurgy is pretty interesting to me. Not that I'm an expert, I've just learned enough to make decisions with what tiny bit of knowledge I have gained.
Old Oct 3, 2018 | 04:54 PM
Darth_V8r's Avatar
Moderator
Thanks. It's a tough topic sometimes to explain. I actually use a rubik's cube to demonstrate the molecular lattice when I'm giving presentations. I do it for a living, so thank God I love the topic.
Old Oct 3, 2018 | 06:07 PM
Yeah, I had metallurgy in junior college; pretty interesting! It was from there that I knew stress-relieving was done with heat, among other things. The most extreme version of that is annealing which makes steel into putty, relatively speaking. It removes any previous hardening.
Old Oct 3, 2018 | 07:16 PM
LLLosingit's Avatar
Really so what is cold forging then?
Old Apr 10, 2019 | 10:50 PM
BC178's Avatar
So with this stress relief would we see any real world result with it or is that still not the weak link of the stock ls blocks, given had sleeves done. Curious if worth doing or not and if other companies besides just R.E.D do it. Btw I know this is a little old...
Old Apr 11, 2019 | 10:17 AM
cookseyb's Avatar
My machine shop heats the block to 450 degrees F, right at tempering temperature for high high carbon steels if I remember correctly, to clean the baked on grease etc. then shot peens it. They say that it helps maintain stability when boring etc. Plus they look brand new when you get them back.
Old Apr 11, 2019 | 10:44 PM
wannafbody's Avatar
Wow, interesting stuff. I would have thought that shaking aged steel or aluminum would be a scam.
By Brett Foote | 2026-06-04 05:00:17
