Check out the NEWEST Summit Pro LS Cams
Old 01-21-2020, 03:36 PM
  #101
Received 3,165 Likes on 2,471 Posts
Originally Posted by 62nalide
Are the rumors true? John Bewley is going to Summit to be apart of the development side of things? Or just an internet rumor?
Likely to further develop improved toilet scrubbing methodology
The following 2 users liked this post by G Atsma:
JF74chevelle (01-21-2020), SLOW SEDAN (01-22-2020)
Old 01-21-2020, 11:04 PM
  #102
Ford_Assassin's Avatar
Question
Originally Posted by Summitracing
It would be around 15-20 ft. lbs. that you would be losing under 2500 with the 8719 vs the 8718.
Would the 8719 give up more torque under 2500 vs the stock LM7 cam?
Old 01-22-2020, 09:43 AM
  #103
LS1Tech Sponsor
Summitracing's Avatar
Received 1,220 Likes on 660 Posts
Comparing the 8719 to the stock LM7 cam. The 8719 would match or have slightly more torque under 2500. This is due to the increased lift of the 8719 to compensate for the later intake valve closing event.
__________________
800-230-3030
www.SummitRacing.com
Old 01-22-2020, 08:42 PM
  #104
Use ur name's Avatar
Does Summit offer any cams for nitrous applications?
Old 01-23-2020, 07:49 AM
  #105
LS1Tech Sponsor
Yes, we offer cams that are for use with nitrous. Any of our Pro LS Automotive line of cams will work well with nitrous. Also, our stage 2 high lift or higher Pro LS Truck Cams work well with nitrous.
__________________
800-230-3030
Old 01-23-2020, 08:35 AM
  #106
bortous's Avatar
I just want to confirm that all these camshafts work well with nitrous in case you didn't pick that up.
The following 2 users liked this post by bortous:
G Atsma (01-23-2020), JF74chevelle (01-24-2020)
Old 02-03-2020, 02:26 PM
  #107
Question
Need another cam recommendation.....
4.8 LR4 going into my 2wd K5. Truck already has a built 4L80E and 3000 billet converter. 7875 turbo, only looking to push to 10 psi. The truck previously had a 6.0, but my wife wants to start driving it, so it doesn't need a 6.0 on 18 psi. I am limited to .560" with the BTR single coil valve springs I already have. Was just going to leave the stock cam in it, but what would you suggest?
Old 02-03-2020, 03:30 PM
  #108
LS1Tech Sponsor
Originally Posted by G Atsma
Look at the truck cams at Cam Motion. They are even classified to displacement.
This thread is specifically to educate customers on our Pro LS cams.
__________________
800-230-3030
The following users liked this post:
Ford_Assassin (02-03-2020)
Old 02-03-2020, 04:09 PM
  #109
LS1Tech Sponsor
Ford Assassin, thanks for checking with us on another cam recommendation.
With this K5/4.8 turbo combo we have a couple cams in mind. 1st option is the truck stage 1 high-lift SUM-8719 that you previously ordered for the C30 dually. This would be a great fit for a K5 with a turbo 4.8. It has -10 overlap so great for driveability, efficiency, and boost. At .550 lift it will work well with your .560 lift springs.
2nd option would be our stage 2 truck cam SUM-8701. Specs are .523/.524, 218/227, 112+2. This has more duration than we would typically recommend for a 4.8. Given the boost and 3000 converter is why we're throwing this in the ring. It has -1 overlap so it will still have good driveability and work well with boost. The IVC event is moved up to 39 vs. 36 of the 8719. With the .523/.524 lift it will work well with your .560 lift springs.
__________________
800-230-3030
Old 02-03-2020, 05:41 PM
  #110
I deleted my post, and apologize for it. I lost track on who the OP was and posted without thinking.
Old 02-03-2020, 05:51 PM
  #111
Actually the C30 is getting the 6.0 that came out of the K5 and receiving the 8719 camshaft. I ended up selling the 5.3.
I am sure it will work fine in the 6.0 too.
Old 02-04-2020, 09:26 AM
  #112
LS1Tech Sponsor
Ford Assassin,
Yes, the 8719 will work well with a boosted 6.0 in your dually.
__________________
800-230-3030
Old 02-17-2020, 08:43 PM
  #113
dmaxs10's Avatar
Deffently want to get a cam but debating what one. 8706 or 8716. 6.0 with a t6 1.32 s475, 4l80e, 3200 stall, 3.50 rear gear, and around 3600 lbs. I would think the 8716 would help the turbo spool quicker but how much will be lost down low for street driving?
Or I could be completely wrong, wouldn't be the first time.
Thanks in advance
Old 02-18-2020, 01:32 PM
  #114
LS1Tech Sponsor
Thanks in advance
You’re right. You could go either way on this with your gear and converter. The earlier exhaust opening of stage 3 SUM-8716 would help the turbo spool. What's offset is a loss of torque off the line from the 4 degree later intake closing. We’re leaning toward the stage 2 SUM-8706 and know it will make you happy. If your traction limited, you might actually be a little faster with 8716. If you have a lot of hook, stage 2 is likely going to accelerate a little harder. To give you an idea, we’re actually using our stage 3 over our own stage 4 in a 408 CID project.
__________________
800-230-3030
Old 02-18-2020, 03:26 PM
  #115
dmaxs10's Avatar
cool thanks
I think I will try the stage 3,. It is in a s10 so not a lot of weight out back to help with traction. Worst case scenario i dont like it and swap it out for a stage 2 someday.
I have a 5.3 with a cam close to the stage 2 right now but with stock converter in it. Its pretty sluggish down low right now cant get much worse lol
Old 02-18-2020, 08:36 PM
  #116
DualQuadDave's Avatar
What 4l80e 3500rpm converters do you have for a 5.3/S480 billet wheel application G body street car, appx 1000hp? Please, no B&M or TCI ones. If your house brand is good, will try it. Thanks!
Old 02-19-2020, 09:55 AM
  #117
LS1Tech Sponsor
cool thanks
Good deal. It comes down to your decision about what you think will work best for you.
__________________
800-230-3030
Old 02-24-2020, 03:49 PM
  #118
wes302's Avatar
SUM 8717 designed to work with 6.0 ly6 with 823 heads?
Old 02-24-2020, 04:09 PM
  #119
old motorhead's Avatar
What does a cam that doesn't work well with nitrous look like? My last nitrous rig was 40 years ago. It absolutely ROCKED with a mild n/a cam.
Old 02-25-2020, 09:38 AM
  #120
LS1Tech Sponsor
The Stage 4 turbo cam SUM-8717 is close on piston to valve clearance with the big 2.165 intake valves. Intake clearance will be .061” on a piston without valve reliefs. The stage 4 is happiest with big displacement, rpm, converter, gear, and a valvetrain happy in the 7500+ range. This may be the cam for you, but can you tell us a little more about your combination and goals?
__________________
800-230-3030
Quick Reply: Check out the NEWEST Summit Pro LS Cams
