5.3 lmg to 5.7 help
Old Oct 11, 2018 | 08:43 PM
IvAAssassin's Avatar
Default 5.3 lmg to 5.7 help
What all would I need to do to make my 5.3 into a 5.7?
2012 silverado 5.3 6l80e trans
Old Oct 11, 2018 | 09:37 PM
Iron or aluminum block? The iron block can be bored to 5.7 specs, but I'm not sure the aluminum one can. Besides that, 5.7 pistons and rings are all you need. Call WS6store for this stuff. They'll give you a good deal and great service. They are a vendor/sponsor of this site. You will need a new tune after this, too.
Old Oct 11, 2018 | 09:38 PM
Lmg cast iron with 799 heads
Old Oct 11, 2018 | 09:48 PM
Should be able to do it then. As I said, call WS6store for the required parts. They'll steer you to whatever else you need. They'll do you right!
Old Oct 11, 2018 | 09:50 PM
I didnt wanna ask them till I was for sure I've already asked a bunch of questions about a 5.3 hot cam from them lol
Old Oct 11, 2018 | 09:57 PM
They're good guys, and as long as you show that you're just not stringing them along they'll bend over backwards to help you. They know a lot of guys want to get a good idea of what to do in their heads before they cut loose with the long green, lol.
BTW, I hope you know that 799 heads are identical to 243's, so you know you already have pretty decent heads on that engine.
Old Oct 12, 2018 | 06:34 AM
Ok cool and ya and I am still planning on porting and polishing them
Old Oct 12, 2018 | 10:12 AM
Get them CNC ported. "Porting and polishing" is an old term. Nobody polishes anymore, as it's now known the CNC finish is as good as need be.
Old Oct 12, 2018 | 10:58 AM
I'm getting texas speed to do them
Old Oct 12, 2018 | 01:34 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Why are you starting so many many threads? Im sure i gave you all the info you needed in your original thread plus emails.
One thread will make it way easier to keep track of and use as reference for all of your questions.
As far as the 5.3 to 5.7 build goes, we have all the parts for less than a set of forged pistons. ALL of the parts.
The only thing youll need is a bore to piston size.
Old Oct 12, 2018 | 02:57 PM
Ok thank you and I didnt want to ask you so many questions because I have already asked Alot
Old Oct 12, 2018 | 03:30 PM
^^^^^^^DO this! ^^^^^^^^^ One stop, no headache shopping...
Old Oct 12, 2018 | 05:24 PM
Engine was changed out perhaps? LMG was a SUV engine, not a truck engine. My 2012 Silverado has an aluminum engine, and every other 2012 I’ve seen had an aluminum engine.
Old Oct 12, 2018 | 05:37 PM
Alex_olds's Avatar
I called them today about my heads on my LM7. Very friendly bunch.
Old Oct 12, 2018 | 06:34 PM
RetroModChevy's Avatar
I've been sincerely trying to avoid thread-jacking or making a whole new thread, but seeing as I have yet to get a definitive answer I'm going to ask it here....
I acquired an LM4 w/ 243 heads. It's an aluminum block 5.3L.
I want to do a "poor man's" LS1 by punching it out to 5.7L. My one question is.... Is it possible to do it safely without hindering reliability?
Old Oct 12, 2018 | 07:00 PM
With our ls1 conversion setup its 100% reliable for the life of the vehicle honestly. ive built iron and alum 5.7s years ago that are running today still.
Old Oct 12, 2018 | 07:03 PM
I appreciate the answer, sir. Scooting over to your site now to check it out!
