2012 CTSV supercharger to 2012 C6??
A friend on mine has a 2012 CTSV which i will be putting all new internals and going with a larger KB supercharger. His friend has a 2012 C6 and wants to put that on his C6.Aside from the hood, what else will need to be done. Is the crank snout the same? Accessory location/bracket change. The SC only has 12k on it and is selling it to his buddy for.....$800.00
I'm sure there will be some plumbing changes but will it work?
Its been done, might want to search on the corvetteforums. The LSA engine does use Corvette spacing for the accessories but the LSA damper has a 3rd pulley/idler/tensioner that drives the blower. He’s going to need a bunch of additional hardware that it sounds like you’re already aware of. Will likely need an aftermarket hood with extra real estate on top too.
