Blow By Issues (Compression + Leakdown Results)
I suspected that you were using a high volume pump well before you said so. That is causing most of your issue.
You dont have a use for it so why use it? Where do you think that extra volume goes when there is no need for it?
Ive literally been preaching this for the past year or more.
DO NOT USE HIGH VOLUME PUMPS ON LS ENGINES.
The only ones that MAY need them are ones with oil accumulators or very large oil coolers or vvt/afm. Otherwise you do not need it and it will cause problems.
Not sure what you consider very large. I have suspected that this is a cause.
Agreed, we're running a conservative red line (6,600 if I remember correctly) and the car weighs 2600lbs so the hope was we weren't putting excessive loads on it
LS1Tech Premium Sponsor
Interesting. I do have an oil cooler: https://www.cxracing.com/OC-248-30-AN10
Ive never really seen a reason for them in ls. quite a few guys will run a high volume pump then think its ok to put the stock pressure spring in and its good because they are having seal issues...then they have to put in restrictors also. Bandiads for the real issue.
Ditch the high volume pump. it will alleviate a few issues.
Are you hooking these lines through the catch can and to the intake manifold and throttle body? If so I can see you pulling oil into the catch can so why not ditch the PCV setup and run each valve cover to a breather can.
10AN lines of each valve cover to the breather can. No more oil being sucked into a can to see. All I've ever seen come out of the breather can is condensation.
If I where to do it differently I would run a breather can for each valve cover and set them up to go under my hood stops.
I have also read about high volume oil pumps being a concern. I read that during an Australian burn out contest a Ls2 while burning rubber on a race track while going into a slight up hill section would loose his crank bearings! The owner found that the high volume oil pump he was running would suck his pan dry! That's an impressive pump. Or is it? This is why I have always stayed away from them.
