Cathedral vs Ls3 test
But as far as that combo goes i would start by chucking that ls3 intake and 90mm tb for a 408.
Just because someone bought a bunch of suspension parts don't mean it's better either.....sometimes it just means they bought a bunch of suspension parts.
for the most part, unless you are a master at designing these engines, the best most of us can do is understand the principles behind this stuff, and look at people's combos to see what works or not.
and it is relatively amazing what a full-bolt-on cathedral head LS can put out. 6.0's putting out close to 400whp with nothing but bolt-on's is fairly good, just have to find a way to put that to the ground as best possible.
Fast forward...
Wtf wrong wif my motor no whorespowers!
@Tusky - I would need to see how the car was driven, but my gut is 408 with ls3 heads but no rpm or choked off with a smaller intake or crappy Y pipe. I generally see a lot of 408 in particular underperform. Regardless if its ls3 or cathedral headed. Idk why. One of the reasons I went 428.
Fast forward...
Edit -- and it moved peak hp up in rpm, so it carried further.
except when you go to wot to race. Then you’re at 100% throttle. So do you downshift to get to 5000 rpm, or do you upshift so you can be at 2500-3000 rpm because you have tq there
Cmon. and no cam specs plus fairly low cr for a 427 even.
Since tfs offers both a rect port and cathedral why didnt they test them?
The actual list of what is the same between the two is shortblock and both use a holley hi ram.
The rest of it falls into the gray area between the pages so to speak.
"The cams are close" - way too broad and vague
Timing curves very close? Ive seen quite a few cathedrals take 28 to 30* and quite a few rect ports take 24 to 26*....so cmon.
And only showing a graph from 4800 and up...thats pretty ridiculous.
None of that passes the sniff test, especially since ive seen odd torque dips on most ls3 headed setups vs cathedral in the lower mid-range rpms. Those that either dyno alot or compare alot know what i am talking about. Cathedrals normally dont do that unless the engine dyno operator loads the test cell differently.
That is really why i prefer chassis dyno as you can see a cleaner graph in alot of aspects as well and see how it will really act in a vehicle. You can then compare between the two also if you want which is what dynos are really for.
Too many secrets to borrow from Sneakers....but too many questions also.
At least 50% relevant...but not more than 75% imo
