LS3 in an fbody "oil turbulence?"
I'm just curious if there is an incompatibility here that would cause the crank to experience more oil turbulence? Oil turbulence causes oil mist really bad is the reason I ask.
There is no incompatibility. The crank in an LS3 is about identical (same stroke) as the 5.7 unit.
You do NOT change out the LS3 crank.
You DO put a 24X reluctor on the LS3 crank
LPE 58x to 24x Crank Signal Converter TRG-002
youll also need ls3 timing cover, 1x Cam gear (if you swap the reluctor), Cam sensor extension harness (double check the pin outs as they can often be wired backwards) knock sensor extensions and tap the block for ls1 knock sensors.
