LS3 416 or sleeved 427?
Pricing is similar for both options. Is one superior to the other? My main concern is reliability/durability - does sleeving the block create any new possible failure points?
Given the same attention to build quality - there is no strength comparison between a stroked LS3 and a Darton sleeved (esp a MID wet sleeve) LS3. Not only will the Sleeved engine make a few more ponies - it will keep a straighter bore and hold together longer. The factory bores move and that matters when you start pushing past 600rwhp and is one more reason why at some power level things break. LS blocks move around when under high stress - it's well known by race engine builders and why they prefer aftermarket blocks or will Darton sleeve if they have to use the factory block.
I agree with the earlier post - at 440 cubes a 250 degree intake @ 050 (tho I'd keep the exhaust close to that - not a big split) is going to rock, it'll be awesome.
Taking an LS block and doing a quality sleevie install looks like it adds about $2,000 give or take to the cost of the block. With a shop like Race Engine Development or Bischoff Engine Service, if a sleeved block fit the budget, I'd go for it over a LS3/LSA block 416, for the reasons mentioned above. Who's doing the work and their attention to detail really matters.
If it's some generic vendor's sleeved block I stick with the LS3/LSA block 416.
That's my .02
@99 Black Bird T/A ..... a quality job and you will not have an issue. So pay the best to do the work, like the guy who designed the sleeves in the first place.....RED.
KW
